    HTTP timeout from laptop but not phone/tablet
    • unstableTable
      unstableTable last edited by
      Hi, thanks for letting me be part of this community.
      Problem:
      HTTP request has timed out, occurs only on my Macbook. Works fine from smartphones and tablets. I'm not sure how to proceed and I would appreciate any help, thanks!
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-9T6BU-FG3S0-7JKF0-3S46Q-KU47D
      Used output buffers: 3 of 20 (14 max)
      Static ram: 28380
      Dynamic ram: 95864 of which 0 recycled
      Exception stack ram used: 348
      Never used ram: 6480
      Task NETWORK ready, free stack 324
      Task HEAT blocked, free stack 1256
      Task MAIN running, free stack 3568
      Last reset 00:04:56 ago, cause: power up
      Last software reset at 2019-04-08 18:50, reason: User, spinning module GCodes, available RAM 6440 bytes (slot 0)
      Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
      Error status: 0
      Free file entries: 10
      MCU temperature: min 33.7, current 33.7, max 34.0
      Supply voltage: min 24.3, current 24.4, max 24.4, under voltage events: 0, over voltage events: 0
      Date/time: 2019-04-08 21:36:37
      Slowest loop: 181.61ms; fastest: 0.08ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 7, completed moves: 7
      Bed compensation in use: none
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 4.40ms; fastest: 0.01ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is running
        Failed messages: pending 175, notready 0, noresp 0
        WiFi firmware version 1.21
        WiFi MAC address 84:f3:eb:83:32:f4
        WiFi Vcc 3.39, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 14224
        WiFi IP address 192.168.1.105
        WiFi signal strength -34dBm, reconnections 0, sleep mode modem
        === Expansion ===
      confitg.g
      ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
      M550 Pe3 ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z400 E95 ; Set steps per mm
      M566 X600 Y600 Z24 E300 ; Set maximum instantaneous speed changes (mm/min) was 1200 you changed it to 600
      M203 X30000 Y30000 Z300 E1500 ; Set maximum speeds (mm/min)
      M201 X300 Y300 Z100 E5000 ; Set accelerations (mm/s^2) was 500 you changed it to 300 for stall guard
      M906 X500 Y500 Z500 E500 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
      M208 X258.5 Y246 Z260 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set active high endstops
      M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M307 H4 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H2.5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-31 Y0 Z.6 ; Set Z probe trigger value, offset and trigger height
      M557 X50:185 Y50:185 S65 ; Define mesh grid M557 X20:215 Y20:215 S65
      M106 P1 S1 I0 F500 H0 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings
      ;M591 D0 P5 C3 R10:300 E3.0 S1 ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance ;10 to 120%, 3mm comparison length
        I see you're running an older version of the firmware and wifi server. You might see some better results by updating to the 2.02 firmware.
        https://github.com/dc42/RepRapFirmware/releases/tag/2.02
        To upgrade from firmware 2.0 or later, upload the Duet2Firmware-2.02.zip file through the Settings/General tab of Duret Web Control. This file also includes Duet Web Control 1.22.6 and DuetWiFiServer 1.21.
        https://github.com/dc42/RepRapFirmware/releases/download/2.02/Duet2Firmware-2.02b.zip
        • unstableTable
          Thanks, I will try that as soon as I get back home. I appreciate the help!
