    BLtouch - strange behavior
    • falcar
      falcar last edited by
      Good morning all:
      I have been using an EZabl for a while and had very weird consistency issues with it. So i've switched to a genuine BLtouch and have had great results!
      The only problem I've had is every so often, the probe starts flashing. The only way I've been able to resolve it is to restart the printer a number of times.
      I can clear the flashing with a macro:
      M280 P64 S160 ; Alarm Release and Push-Pin UP
      But then when I try to deploy the pin again (M280 P64 S10 ) it just starts flashing again.
      I'm really out of ideas. Any thoughts?
      Its a Maestro board and here is my config.g:
      ; generated by RepRapFirmware Configuration Tool v2 on Mon Mar 11 2019 13:47:47 GMT-0500 (Central Daylight Time)
      M550 P"Ender 3" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M552 P192.168.1.14
      M554 P192.168.1.1
      M553 255.255.255.0
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E393.00 ; Set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
      M906 X600.00 Y600.00 Z600.00 E700.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M572 D0 S0.05 ; Pressure Advance
      M208 X-5.5 Y-10 Z0 S1 ; Set axis minima
      M208 X258.5 Y246 Z260 S0 ; Set axis maxima
      M574 X1 Y1 S1 ; Set endstops
      ; M558 I1 P5 H5 F120 T6000 ; EZABL Set Z probe type to unmodulated and the dive height + speeds
      M558 P9 F100 H5 R0.2 T6000 ; new BL
      ; G31 P100 X0 Y20 Z3.2 ; Set Z probe trigger value, offset and trigger height
      ; G31 P100 X41 Y0 Z1.7 ; EZABL Offset
      G31 P100 X36 Y0 Z3.150 ; BLTOUCH
      M557 X35:215 Y25:215 S40 ; Define mesh grid M557 X20:215 Y20:215 S65
      M305 P0 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4138 R2200 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
        It sounds like your pin may be damaged or dirty. You can take it out of the housing to check it and clean it with the grub screw at the top of the probe.
          The flashing means that the BLTouch is in an error state. There is a M280 command you can send to reset it, but I don't have the details right now.
          • Veti
            Veti last edited by
            the bltouch goes into error state if it cant deploy or retract.
            most of the time it can be fixed by adjusting the grub screw at the top.
            sometimes you have to fix the heatshrink on the pin.
            • falcar
              Thanks guys. I took it apart and Everything looked ok. I did clean it off and reassembled it. Let’s see if that helps.
              Thanks again for the responses. This one had me stumped.
