    Ender 3 heater displaying crazy numbers
    810
    • BearcatTDundefined
      BearcatTD
      I have my Duet 2 wifi connected to my Ender three with a micro swiss hotend. In the web application the hotend temp is reading in the 1100c range, but not heating. I am using the stock heater and a new thermistor which I believe are connected properly. I put a continuity check on both the heater and the therm and there seems to be continuity through the piece.
      Short of replacing it, are there any suggestions to try?!
      Thanks,
      Pat
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      • botundefined
        bot
        Have you configured your thermistor in config.g? You need to set the parameters for it to measure correctly.
        *not actually a robot
        BearcatTDundefined 2 Replies Last reply Reply Quote 0
          BearcatTD @bot
          @bot
          ahhhh!!! Thanks! For a robot, you move very quickly! LOL! Thanks again!
          botundefined 1 Reply Last reply Reply Quote 1
          • botundefined
            bot @BearcatTD
            Phaedruxundefined 1 Reply Last reply Reply Quote 1
              Phaedrux Moderator @bot
              @bot said in Ender 3 heater displaying crazy numbers:
              That's exactly what a robot would say. 😒
              • botundefined
                bot @Phaedrux
                I can not possibly be a robot I checked the checkbox!!
                  BearcatTD @bot
                  @bot
                  Again, this is for an Ender 3 and the type of thermistor is: 3D Printer Thermistor NTC 100K ohm 5pcs for mk7 mk8 Nozzle and Heated Bed for Creality CR-10 CR-10S Ender 3 Eewolf (From Amazon)
                  Here is what my config.g reads:
                  I'm not sure what some of these numbers mean?
                  • Vetiundefined
                    Veti
                    the ender 3 uses epocs 100k thermistors for the bed and hotend.
                    see
                    https://forum.duet3d.com/topic/9464/m305-thermistor-values-for-the-duet-maestro-on-the-ender-3-pro/9
