    Suddenly Started printing higher than usual
    My Duet controlled machine
    530
    • jtroutt19
      jtroutt19 last edited by
      So I didnt change anything. Printed a vase the night before everything printed great. Today went to print a new duct for 5015 fan and when I send the file over from cura the printer starts but .45mm above the 0 point on the Z axis.
      The probe trigger point is still correct it triggers at .73mm. I literally have not changed anything. What I had to do to get it to print properly is a G92 command after manually moving the nozzle to the proper height and then send my file over.
      Is this something I have overlooked? Did something happen that i dont know about?
      ; generated by RepRapFirmware Configuration Tool on Thu Sep 06 2018 21:21:12 GMT-0700 (Pacific Daylight Time)
      G90                                                ; Send absolute coordinates...
      M550 Pe3                                           ; Set machine name
      M552 S1                                            ; Enable network
      M586 P0 S1                                         ; Enable HTTP
      M586 P1 S0                                         ; Disable FTP
      M586 P2 S0                                         ; Disable Telnet
      M569 P0 S0                                         ; Drive 0 goes backwards
      M569 P1 S0                                         ; Drive 1 goes backwards
      M569 P2 S1                                         ; Drive 2 goes forwards
      M569 P3 S0                                         ; Drive 3 goes backwards
      M350 X16 Y16 Z16 E16 I1                            ; Configure microstepping with interpolation
      M92 X80 Y80 Z400 E106.29                           ; Set steps per mm
      M566 X600 Y600 Z24 E300                            ; Set maximum instantaneous speed changes (mm/min) was 1200 you changed it to 600
      M203 X30000 Y30000 Z300 E1500                      ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z100 E5000                          ; Set accelerations (mm/s^2)
      M906 X500 Y500 Z500 E500 I30                       ; Set motor currents (mA) and motor idle factor in per cent
      M84 S300                                           ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1                              ; Set axis minima
      M208 X258.5 Y246 Z260 S0                           ; Set axis maxima
      M574 X1 Y1 S1                                      ; Set active high endstops
      M574 Z1 S2                                         ; Set endstops controlled by probe
      M307 H3 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
      M307 H4 A-1 C-1 D-1                                ; Disable heater on PWM channel for BLTouch
      M558 P9 H4.0 F120 T6000                            ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-31 Y0 Z0.73                              ; Set Z probe trigger value, offset and trigger height
      M557 X50:185 Y50:185 S65                           ; Define mesh grid    M557 X20:215 Y20:215 S65
      M305 P0 T100000 B4138 C0 R4700                     ; Set thermistor + ADC parameters for heater 0
      M143 H0 S120                                       ; Set temperature limit for heater 0 to 120C
      M305 P1 T100000 B4138 C0 R4700                     ; Set thermistor + ADC parameters for heater 1
      M143 H1 S280                                       ; Set temperature limit for heater 1 to 280C
      ;M106 P0 S1 H1 T45 C"Part Cooling"                  ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S1 H1 T45 C"Hotend Fan"                    ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1                                      ; Define tool 0
      G10 P0 X0 Y0 Z0                                    ; Set tool 0 axis offsets
      G10 P0 R0 S0                                       ; Set initial tool 0 active and standby temperatures to 0C
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings
      ;M591 D0 P5 C3 R10:300 E3.0 S1			   ; Duet3D laser sensor for extruder drive 0 is connected to endstop input 3 (E0), tolerance 10 to ;120%, 3mm comparison length ```
        Is it consistent every time you home now?
        • jtroutt19
          jtroutt19 last edited by jtroutt19
          Yes it is. If I start a new print I have to pause the print and zero the Z at the correct height then resume printing.
            What do you get when you measure the trigger height with this?
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
            jtroutt19 1 Reply Last reply Reply Quote 0
            • jtroutt19
              jtroutt19 @Phaedrux last edited by
              @phaedrux
              So I get .73 reported in the head position. The very first time I did it it reported back to me in the actual G-Code console. It doesnt do that this go round.
              The first time I did this I followed that exact same procedure and that is where the .73 came from. But that exact value gets reported in the head position box for Z if I do it now. Just wanted to reiterate that.
                So the Z position box will show whatever the G31 z offset is set to when you do a G30 because that's the height you've told it is is when the probe triggers.
                And if G30 S-1 still gives you the same value it should be correct.
                Can you post your homing file?
                • jtroutt19
                  jtroutt19 @Phaedrux last edited by jtroutt19
                  @phaedrux
                  I dont get why all of the sudden it started doing this if nothing got changed.
                  And today my bed is showing 84°c when its cool to the touch....
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool on Sat Sep 29 2018 12:21:44 GMT-0700 (Pacific Daylight Time)
                  G1 Z2.5 F6000 S2        ; lift Z relative to current position
                  M98 Pdeployprobe.g      ; deploy mechanical Z probe
                  G1 S1 X-269 Y-261 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 X5 Y5 F6000          ; go back a few mm
                  G1 S1 X-269 Y-261 F360  ; move slowly to X and Y axis endstops once more (second pass)
                  G1 X51 Y20 F6000        ; go to first bed probe point and home Z
                  G30                     ; home Z by probing the bed
                  ;G91                    ; relative positioning
                  ;G1 S2 Z2.5 F100        ; lift Z relative to current position
                  ;G90                    ; absolute positioning
                  M98 Pretractprobe.g     ; retract mechanical Z probe
                  ; homez.g
                  ; called to home the Z axis
                  G1 X51 Y20 F6000 ; go to first probe point
                    Phaedrux Moderator @jtroutt19 last edited by
                    @jtroutt19 said in Suddenly Started printing higher than usual:
                    That's concerning. Is the wiring and thermistor intact?
                    You should probably remove this from homeall.
                    I can't see anything else in your homing files that's amiss.
                    • jtroutt19
                      @phaedrux
                      I reloaded the firmware and the temp is showing correct again.
                      I dont understand how anything has changed. But I added .4 to my trigger height and it now is at the correct height.
                      Hey while I am here let me ask you. Dual 5015 blowers or just one?
                        Was there possibly a head collision at some point? All it takes is a small shift. Since nothing software wise had changed, some mechanical explanation would seem likely. Wear, damage, binding, loosening parts, etc. Give everything a really good inspection.
                        That depends how much cooling you need and what shroud you're using. I use a single 5015 with a Dii cooler shroud. Depends on the 5015 as well. How powerful are they?
                        jtroutt19 1 Reply Last reply Reply Quote 1
                        • jtroutt19
                          @phaedrux
                          Ahead of ya there. After getting home today I double checked everything. Made sure everything was still tight and square. I couldn't find any issues. But oh well its fixed now.
                          I am using the Petsfang 5015 mount for the hot end cooling with a noctua fan. The blowers other than being brushless and 24v I have not clue about. I ordered them off amazon and they sent me two. I am currently printing the duct to accommodate one of them. I just didnt know of 2 were ever going to be needed.
                          I dont know how much cooling I am going to need. Not sure how to even start answering that question.
                            Start printing. You'll know. One will likely be enough. I'm going to guess that the blowers from amazon are probably a little loud and pretty powerful. And they probably sent two because there's a good chance one will be DOA. So at least you have a spare.
