    Failed to add SSID to remembered list Duet 2 WIFI
    1653
    • Lickett_E_Splitt
      Lickett_E_Splitt last edited by
      Not sure what step to take next. I'm trying to connect to the WIFI network.
      The router is an ASUS RT-AC66R that's hidden. It has WPA2-Personal security if that makes a difference. I've tried both the 2.4 and 5 bands. I set my cellphone as a hotspot and tried that. All with the same results.
      The commands sent are below followed by the results of M122.
      For brevity I cut out the "no known networks found" and "WIFI module is idle" that were between the commands.
      M552 S0
      ok
      WiFi reported error: no known networks found
      M552 S1
      ok
      M587 S"My SSID was here" P"My Network Password was here"
      M587: Failed to add SSID to remembered list
      ok
      Error retrieving WiFi status message: bad reply format version
      WiFi module is idle
      M587
      M587: Failed to retrieve network list
      ok
      WiFi module is idle
      M588 S"*"
      M588: Failed to reset the WiFi module to factory settings
      ok
      WiFi module is idle
      M587
      ok
      WiFi module is idle
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-917DA-G4MSD-6J1F8-3SJ6L-K8TV9
      Used output buffers: 13 of 20 (13 max)
      Static ram: 25524
      Dynamic ram: 98532 of which 0 recycled
      Exception stack ram used: 256
      Never used ram: 6760
      Tasks: NETWORK(ready,1240) HEAT(blocked,1256) MAIN(running,3868) IDLE(ready,200)
      Owned mutexes:
      Last reset 00:01:42 ago, cause: power up
      Last software reset time unknown, reason: Heat task stuck, spinning module Platform, available RAM 6356 bytes (slot 0)
      Software reset code 0x00a0 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x2000493c Task 0x4e49414d
      Stack: 0043ca33 00449aae 41000000 00000000 00000000 00000000 00000000 3e178897 3e1cd04f 41880000 3e3a33b0 3e638eb9 3e92497a 3b750939 3ecccd35 bd7a7541 3f800000 c0a00000 00000000 60000010 00000001 2000855c 0043ca33
      Error status: 0
      Free file entries: 10
      MCU temperature: min 22.5, current 28.1, max 28.1
      Supply voltage: min 0.0, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 195632570
      Slowest loop: 201.06ms; fastest: 0.06ms
      I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      WiFi module is idle
      • nhof
        nhof last edited by
        Couple things to try:
        1. Make sure you are using the latest wifiserver version
        2. Turn the wifi module totally off, then back on to idle (M552 S-1, followed by M552 S0) then try to run the commands again.
          @lickett_e_splitt said in Failed to add SSID to remembered list Duet 2 WIFI:
          As @nhof says. This message:
          suggests that the main and WiFi firmware versions may be out of step. Try upgrading the WiFi firmware to DuetWiFiServer version 1.23, available from https://github.com/dc42/RepRapFirmware/releases/download/2.03beta3/DuetWiFiServer.bin.
          • Lickett_E_Splitt
            I just downloaded the WIFI Firmware from the Github link above, uploaded it, It counted down in 5% increments and I got Upload Successful.
            M122 still reports
            M122
            Used output buffers: 7 of 20 (7 max)
            Then
            M587 S"my SSID" P"My network password"
            ok
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            M587
            ok
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            M552 S1
            ok
            WiFi module is idle
            WiFi module is idle
            WiFi module is idle
            ok
            WiFi module is idle
              Does it actually show version 1.23 for the wifi server version at the end of the M122 report?
                I suspect that your board has a faulty WiFi module, because you shouldn't be getting that "bad reply format version" message. Are you able to read the WiFi firmware version from the WiFi section of the M122 report, as @Phaedrux suggests?
                • Lickett_E_Splitt
                  Sorry, thought I had all the output from M122 that we needed. Here is the full output.
                  WiFi module is idle
                  M122
                  Used output buffers: 4 of 20 (4 max)
                  Static ram: 25524
                  Tasks: NETWORK(ready,1276) HEAT(blocked,1256) MAIN(running,3868) IDLE(ready,200)
                  Owned mutexes:
                  Last reset 00:00:21 ago, cause: power up
                  Error status: 0
                  MCU temperature: min 21.4, current 25.2, max 25.3
                  Supply voltage: min 0.0, current 0.1, max 0.2, under voltage events: 0, over voltage events: 0, power good: no
                  Cache data hit count 39256480
                  Slowest loop: 0.26ms; fastest: 0.06ms
                  Segments left: 0
                  telnet is idle in state(s) 0
                  file is idle in state(s) 0
                  serial is ready with "M122" in state(s) 0
                  aux is idle in state(s) 0
                  daemon is idle in state(s) 0
                  queue is idle in state(s) 0
                  Code queue is empty.
                  === Network ===
                  Slowest loop: 1.27ms; fastest: 0.00ms
                  HTTP sessions: 0 of 8
                  • WiFi -
                    Network state is changing mode
                    WiFi module is idle
                    Failed to get WiFi status
                    ok
                    WiFi module is idle
                    WiFi module is idle
                  • Lickett_E_Splitt
                    Not sure why it looks like the M122 cuts off after Socket States:
                      Please ask for your Duet to be replaced under warranty. i think it needs a new WiFi module.
                      UnderDoneSushi 1 Reply Last reply Reply Quote 0
                      • UnderDoneSushi
                        UnderDoneSushi @dc42 last edited by UnderDoneSushi
                        @dc42 I think I am having the same issue on a v1.02 board that I hadn't ever used and am just now using after over 2 years since buying from Filastruder. I just uploaded Duet2Firmware-2.05.1.zip and DuetWiFiServer-1.23.bin. The wifi module blinks once when plugging into my desktop and M122 reads as follows ---
                        === Network ===
                        Slowest loop: 1.25ms; fastest: 0.00ms
                        - WiFi -
                        WiFi module is idle
                        Failed messages: pending 0, notready 0, noresp 2
                        A Former User 1 Reply Last reply Reply Quote 0
                        • A Former User
                          A Former User @UnderDoneSushi last edited by
                          @UnderDoneSushi said in Failed to add SSID to remembered list Duet 2 WIFI:
                          probably best to make a new topic instead of adding to a year old one.
                          create the macros from the link below then run them, or send each individual command from all three over USB and post the output of it all in a new topic if it doesn't sort the issue. (you can skip M291)
                          also substitute your own wifi details in M587 ofc.
                          https://forum.duet3d.com/post/139882
                          UnderDoneSushi 1 Reply Last reply Reply Quote 1
                          • UnderDoneSushi
                            UnderDoneSushi @Guest last edited by
                            @bearer thank bearer, yeah I should have just posted it in a new one
