    Wifi and web wont update
    Firmware installation
    • patterson6
      patterson6 last edited by
      Firmware Name: RepRapFirmware for Duet WiFi
      Firmware Version: 1.17e (2017-02-10)
      WiFi Server Version: 1.02
      Web Interface Version: 1.12-RC1
      The board is just powered by usb
      This is where i am at. I can connect to it via web. I will click on upload files they download and i click on yes install. It goes updating wifi server then when its done i get an error invalid password because it logs me off. I try to log on again and my wifi password don't work anymore. I cant log back on to the page until i reset my duetwifi and log back on the browser.
      before i reset the board
      I will then click on repertier and connect and get this
      04:18:51.102 : OpenGL renderer:GeForce GTX 980/PCIe/SSE2
      04:18:51.102 : Using fast VBOs for rendering is possible
      04:21:31.876 : Printer reset detected - initalizing
      04:21:31.877 : WiFi server starting up
      04:21:31.878 : Error: Temperature reading fault on heater 1: sensor open circuit
      04:21:31.878 : DuetWiFiServer version 1.02
      04:21:32.123 : N1 M11034
      04:21:32.123 : N2 M115
      36
      04:21:32.123 : N3 M10536
      04:21:32.123 : N4 M114
      35
      04:21:32.123 : N5 M111 S698
      04:21:32.139 : N6 T0
      60
      04:21:32.141 : N7 M8028
      04:21:32.141 : N8 M105
      47
      04:21:32.143 : Flash size 41ok
      04:21:32.144 : FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.17e ELECTRONICS: Duet WiFi 1.0 FIRMWARE_DATE: 2017-02-10
      I enter M997S1 and get this
      04:25:00.040 : Trying to connect at 460800 baud: failed
      04:25:00.352 : N79 M105*25
      04:25:11.000 : Trying to connect at 230400 baud: failed
      04:25:21.959 : Trying to connect at 115200 baud: failed
      04:25:32.919 : Trying to connect at 74880 baud: failed
      04:25:32.919 : Error: Installation failed due to comm write error
      I get the same error for M997S2
      If i enter M552S0 and M552S1 i get this
      04:28:49.175 : ok
      04:28:49.175 : WiFi server starting up
      04:28:49.175 : Request: connect?password=reprap fragment 2147483648
      04:28:49.175 : Resp 2147483648: 000100c8 00000039 {"er…s
      04:28:50.052 : N140 M10534
      04:28:50.053 : serial: N140 M105
      34
      04:28:50.054 : ok T:B:-273.1
      04:28:53.114 : N141 M10535
      04:28:53.115 : serial: N141 M105
      35
      04:28:53.116 : ok T:B:-273.1
      04:28:56.175 : N142 M10532
      04:28:56.176 : serial: N142 M105
      32
      04:28:56.177 : ok T:B:-273.1
      04:28:59.237 : N143 M10533
      04:28:59.238 : serial: N143 M105
      33
      04:28:59.239 : ok T:B:-273.1
      04:29:02.299 : N144 M10538
      04:29:02.300 : serial: N144 M105
      38
      04:29:02.301 : ok T:B:-273.1
      04:29:03.733 : Class Platform spinning.
      04:29:03.733 : Class Webserver spinning.
      04:29:03.733 : Class GCodes spinning.
      04:29:03.733 : Class Move spinning.
      04:29:03.735 : Class PrintMonitor spinning.
      04:29:03.735 : Class Heat spinning.
      If i Try to install it with Repetier open i seen this
      04:31:10.899 : Trying to connect at 460800 baud: serial: N186 M10540
      04:31:10.900 : ok T:B:-273.1
      04:31:13.963 : N187 M105
      41
      04:31:14.390 : serial: N187 M10541
      04:31:14.391 : ok T:B:-273.1
      04:31:17.023 : N188 M105
      38
      04:31:18.043 : serial: N188 M10538
      04:31:18.044 : ok T:B:-273.1
      04:31:20.090 : N189 M105
      39
      04:31:20.595 : serial: N189 M10539
      04:31:20.596 : ok T:B:-273.1
      04:31:21.647 : failed
      04:31:23.151 : N190 M105
      47
      04:31:23.198 : Trying to connect at 230400 baud: serial: N190 M10547
      04:31:23.199 : ok T:B:-273.1
      04:31:26.216 : N191 M105
      46
      04:31:26.851 : serial: N191 M10546
      04:31:26.852 : ok T:B:-273.1
      04:31:29.274 : N192 M105
      45
      04:31:29.275 : serial: N192 M10545
      04:31:29.276 : ok T:B:-273.1
      04:31:32.336 : N193 M105
      44
      04:31:32.606 : failed
      04:31:32.656 : Trying to connect at 115200 baud: serial: N193 M10544
      04:31:32.657 : ok T:B:-273.1
      04:31:35.400 : N194 M105
      43
      04:31:36.259 : serial: N194 M10543
      04:31:36.260 : ok T:B:-273.1
      04:31:38.464 : N195 M105
      42
      04:31:38.863 : serial: N195 M10542
      04:31:38.864 : ok T:B:-273.1
      04:31:41.523 : N196 M105
      41
      04:31:42.515 : serial: N196 M10541
      04:31:42.516 : ok T:B:-273.1
      04:31:43.567 : failed
      04:31:44.591 : N197 M105
      40
      04:31:45.118 : Trying to connect at 74880 baud: serial: N197 M10540
      04:31:45.119 : ok T:B:-273.1
      04:31:47.650 : N198 M105
      39
      04:31:47.651 : serial: N198 M10539
      04:31:47.652 : ok T:B:-273.1
      04:31:50.713 : N199 M105
      38
      04:31:50.923 : serial: N199 M10538
      04:31:50.924 : ok T:B:-273.1
      04:31:53.776 : N200 M105
      37
      04:31:54.527 : failed
      04:31:54.528 : Error: Installation failed due to comm write error
      But i can still connect via web if i again reset the board and open up the browser. I did not try the sd card in the computer method because i don't have a way of reading and writing it yet. I ordered something on amazon.
      • Jackal
        Jackal last edited by
        You need main power to update the wifi server
          Try again with VIN power applied to the board (if you have a PanelDue connected, it may be sufficient to try again with the PanelDue disconnected). If you still get this:
          then ask for a replacement Duet WiFi. A small minority of WiFi modules refuse to program in the field, even though we used exactly the same mechanism to program them in the factory. The most recent production boards have a component value change to avoid this issue.
          • Cata
            Cata last edited by
            I have that problem, finally it return to the seller. Not funny, 70 USD fees when arrive to my country and 30 USD shipping cost to send back.
            • patterson6
              Ok, so hooking up the vin didn't work. I received a new duet wifi in the mail a few days ago. Now i can connect to the wifi it seems in repetier. However it wont connect in the browser when i enter 192.168.1.119. Is this a mac issue since my old card was used on my network? how do i fix this?
              Here is what i have on repetier so it seems to be up and running.
              04:52:22.309 : DuetWiFiServer version 1.02
              04:52:22.309 : Flash size 4194304, free RAM 31504 bytes, WiFi Vcc 3.40V, host name: duetwifi, reset reason: Turned on by main processor
              04:52:22.309 : WiFi server connected to access point Neal's DN, IP=192.168.1.119, signal strength=-67dBm
              04:52:25.310 : N62 M10519
              04:52:25.310 : serial: N62 M105
              19
              04:52:25.310 : ok T:B:-273.1
              04:52:28.372 : N63 M10518
              04:52:28.372 : serial: N63 M105
              18
              04:52:28.372 : ok T:B:-273.1
              04:52:29.091 : Class Platform spinning.
              04:52:29.622 : Class GCodes spinning.
              04:52:29.622 : Class Heat spinning.
              04:52:29.622 : Class PrintMonitor spinning.
              04:52:29.622 : Class Webserver spinning.
              04:52:29.622 : Class Move spinning.
              I am also alarmed that this new card is still old so i hope if i can get past this hurdle i don't have the same problems as last time. Both cards are from filastruder. Hope its not the same batch.
              04:49:52.176 : FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.15b ELECTRONICS: Duet WiFi 1.0 DATE: 2016-08-25
                @Cata:
                I'm sorry to hear that. If you ever have to ask for a replacement for goods you have imported, ask the seller to make it clear in the customs declaration that what they are sending is a replacement for faulty goods that you have previously purchased, with zero customs value, That way you should not have to pay any import fees.
