Duex 5 servo question
Question for @dc42,
I am in the middle of commisioning my custom toolchanger using sg90 servos, after reading the guide for connecting servos you mention this:
When a servo stops moving, it can pump a large amount of energy into the +5v rail due to regenerative braking. If unchecked, this may increase the voltage of the +5V rail above the safe limit. The 1.04 revision of the Duet 2 WiFi/Ethernet has an extra 220uF capacitor on the 5v rail to help absorb this, so does the Duet 2 Maestro. Older Duets don't. So when using servos with them it is advisable to add your own 220uF capacitor between the +5V and ground servo wires.
Question: Does this count for the Duex5/2?
Yes it does, if your Duet is not the 1.04 revision.
Thanks for replying David.
I have a 1.03 board, will add the capacitor as advised on my Duex5 servo outputs.
Maybe reflect this on the wiki as it wasn't totally clear to me
I have revised that text.
