    PT100 Sensor Daughterboard
    372
    • PMJ
      PMJ last edited by
      Duet Ethernet
      Duex5
      Daughterboard PT100 connected on Duex5 (but also tried on Duet itself)
      Channel 1: 2 wire PT100 with jumpers installed
      Channel 2 4 wire PT100 without jumpers
      Both sensors measure 108.9 ohm
      Changed in config.g
      M305 P0 X204
      M305 P1 X205
      Also tried with 100 ohm resistor (with jumpers) on both channels.
      Also gave a try to do it on Duet mainboard with X200/X201
      All with the same result: 2000°C...
      Also tried two brand new PT100 daughterboards (V1.1) - nothing changed...
      Any ideas??? 🆘
        When you send or re-send the M305 command, what is the response?
        Do you have a PanelDue or an external SD card connected to CONN_SD using the ribbon cable? If so, does the PT100 work if you disconnect that?
        • PMJ
          PMJ last edited by
          No, nothing connected on that interfaces. Actually only the Mini USB and Ethernet. Mini USB is for receiving G Codes and ethernet only for maintenance reasons...
          dc42 Veti 2 Replies Last reply Reply Quote 0
            dc42 administrators @PMJ last edited by
            OK, so what response do you get when you re-send the M305 command?
            • PMJ
              PMJ last edited by
              When resending all seems to be fine. In webinterface it is green and i my console I get an OK.
              • Veti
                Veti @PMJ last edited by
                @pmj said in PT100 Sensor Daughterboard:
                on a side node. are you aware of this?
                https://duet3d.dozuki.com/Wiki/USB_ground_loops
                PMJ 1 Reply Last reply Reply Quote 0
                  1. Which firmware version are you running?
                  2. Please provide your complete config.g file.
                  3. Which devices have the PT100 sensors? Your use of P0 and P1 in the M305 commands suggests the bed heater and the first extruder heater: is that correct?
                  • PMJ
                    PMJ last edited by
                    now I've found time again to solve the PT100 issue. Still the same situation showing up 2000C... All double checked again and went through all forum.
                    Firmware: Just updated today from 2.02 to 2.03 latest RC => no change
                    config.g attached (without some details)
                    Devices:
                    P0 => general temperature measurement up to 80°C (2-wire, with conbectors on X205)
                    P1 => Heatbed sensor (4-wire, without connectors on X204)
                    0_1561986375097_config.g
                    • PMJ
                      PMJ @Veti last edited by
                      @veti yes I'm aware of this, anyway thanks for the input 😉
                      • PMJ
                        PMJ last edited by
                        SOLVED!!! Found the failure... overseen, that i changed with M307 also P0 and P1.... canceled the two lines and now working like a charme!
