    one Z stepper getting very hot, other fine?
    927
    • alanknight
      alanknight last edited by alanknight
      Firmware Version: 1.21 (2018-03-21)
      WiFi Server Version: 1.21RC4(08b3)
      Web Interface Version: 1.21-RC4
      Geeetech Acrylic Prusa I3
      (like this https://www.amazon.co.uk/Geeetech-Acrylic-Pro-Unassembled-excellent/dp/B01GJDO9I0/ref=asc_df_B01GJDO9I0/?tag=googshopuk-21&linkCode=df0&hvadid=310830238305&hvpos=1o3&hvnetw=g&hvrand=11726874431904553719&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1007133&hvtargid=pla-562339475169&psc=1 )
      I'm running the 2 z motors on the separate drivers
      printed lots in the past no problem... added a z probe (ir one) and now my second Z stepper motor is getting really hot... hot enough that it melted and deformed the acrylic that it's fixed to
      I thought it was a bad motor, bought another printer just to swap the motor and that bit of acrylic over... but it's still getting hot
      I'm not using bed leveling or mesh compensation etc.
      I'm stuck, any ideas? only thing I can think is either it always got this hot and I didn't notice (I don't think so) or I've changed some setting by accident?
      here's my config file...
      ; generated by RepRapFirmware Configuration Tool on Wed Jun 13 2018 17:00:33 GMT+0100 (British Summer Time)
      M550 PMy printer ; Set machine name
      M552 S1 ; Enable network
      M587 *edited out ; Configure access point and IP addresses. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; Define Drives
      ; Physical Drive connection
      M569 P0 S0 ; X Drive 0 goes backwards
      M569 P1 S0 ; Y Drive 1 goes backwards
      M569 P2 S1 ; Z1 Drive 2 goes forwards
      M569 P3 S1 ; Z2 Drive 3 goes forwards
      M569 P4 S0 ; extr Drive 4 goes backwards
      M350 X16 Y16 Z16:16 E16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z2555:2555 E93 ; Set steps per mm
      M566 X900 Y900 Z6:6 E500 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 Z90:90 E3000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z50:50 E500 ; Set accelerations (mm/s^2)
      M906 X600 Y600 Z750:750 E1600 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      ; Motor remapping for dual Z
      M584 X0 Y1 Z2:3 E4.5
      M208 X200 Y180 Z200 S0 ; Set axis maxima
      M574 X1 Y1 Z1 S0 ; Set active low endstops
      ;M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      ;G31 P500 X0 Y0 Z-2.730 ; Set Z probe trigger value, offset and trigger height
      ;M557 X40:160 Y40:160 S20 ; Define mesh grid
      M143 H1 S320 ; Set temperature limit for heater 1 to 280C
      M106 P0 S0.85 I0 F500 H1 T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0.5 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D0 H1 ; Define tool 0
      I'm lost 😮
        If you send M906 and M913 in the console it should report back what the current is set to and any percentage scaling being applied. See if they match what you have in config.g incase they are being modified at some point after startup or not applied correctly.
        What is the rated max current of the motors? 60-85% of the rated max for the motor is recommended.
        • Veti
          Veti last edited by
          @alanknight said in one Z stepper getting very hot, other fine?:
          E4.5 is wrong you want E4:5
          alanknight 1 Reply Last reply Reply Quote 0
          • alanknight
            I set it printing and it was a bit hot... thought I'd leave it a min, came back after washing my hands, touched it and it sizzled where my hands were wet 😮
            I'll let it cool and then try again, the M906 and M913 commands and fix the E4.5 to E4:5
            (E is extruder and a seperate problem yeah?)
            • alanknight
              just turned it on, not printing
              PMM913
              Motor current % of normal - X:100, Y:100, Z:100, E:100
              PMM906
              Motor current (mA) - X:600, Y:600, Z:750, E:1600, idle factor 30%
              started printing, numbers are all the same
              I'm clutching at straws... but is there a chance one stepper isn't dropping back to idle power levels when it's supposed to?
              • alanknight
                alanknight @Veti last edited by
                @veti said in one Z stepper getting very hot, other fine?:
                my bad, I read that wrong, M584 is for z axis only, fixed it, I'll let it cool and set it printing again
                thanks guys 🙂
                • alanknight
                  printing now again... it's hot as hell again 😞
                    Does anything show in M122?
                    I see you're running a pretty old firmware version. I don't think there were any bugs like this, but you never know. You could try upgrading to 2.02 and seeing if it makes any difference.
                    Just to clarify, you fixed the error Veti pointed out, does M906 and M913 report both Z motors now? Just want to verify that your extruder is the one getting 1600 and not the second Z motor.
                    • alanknight
                      M112 runs an emergency stop?
                      M913
                      Motor current % of normal - X:100, Y:100, Z:100, E: 100:100
                      M906
                      Motor current (mA) - X:600, Y:600, Z:750, E:1600:1600, idle factor 30%
                      are my extruder and Z axis somehow mixed up? the printer prints fine, just that one z motor getting hot
                      (I added a space after E: to avoid the smilie)
                        M112 is emergency stop.
                        M122 is diagnostic report.
                        Painfully close, I know.
                        • alanknight
                          sorry my bad
                          M122
                          Used output buffers: 3 of 32 (11 max)
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                          Board ID: 08DGM-956GU-DJMSN-6J9F4-3SD6Q-1VRRG
                          Static ram used: 16152
                          Dynamic ram used: 100408
                          Recycled dynamic ram: 2224
                          Stack ram used: 1224 current, 4512 maximum
                          Never used ram: 7776
                          Last reset 00:14:34 ago, cause: software
                          Last software reset at 2019-05-02 22:53, reason: User, spinning module GCodes, available RAM 7776 bytes (slot 0)
                          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                          Error status: 0
                          Free file entries: 10
                          MCU temperature: min 34.5, current 35.7, max 35.9
                          Supply voltage: min 12.3, current 12.7, max 13.1, under voltage events: 0, over voltage events: 0
                          Date/time: 2019-05-02 23:08:15
                          Slowest main loop (seconds): 0.014124; fastest: 0.000046
                          MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                          Scheduled moves: 0, completed moves: 0
                          Bed compensation in use: none
                          Heater 0 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by null
                          http is idle in state(s) 0
                          telnet is idle in state(s) 0
                          file is idle in state(s) 0
                          serial is idle in state(s) 0
                          aux is idle in state(s) 0
                          daemon is idle in state(s) 0
                          queue is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                          HTTP sessions: 1 of 8
                          • WiFi -
                            Network state is running
                            WiFi firmware version 1.21RC4(08b3)
                            WiFi MAC address 5c:cf:7f:76:61:21
                            WiFi Vcc 3.31, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 17336
                            WiFi IP address 192.168.1.239
                            WiFi signal strength -50dBm, reconnections 0, sleep mode modem
                            Socket states: 2 0 0 0 0 0 0 0
                            === Expansion ===
                          should I updates? - do I lose my settings if I do?
                          it used to print fine... so I'm assuming I accidentally broke something, but I'm lost
                          • alanknight
                            updated
                            WiFi Server Version: 1.22
                            Web Interface Version: 1.22.6
                            I've added a fan to that stepper for tonight, printer is at work, it's 11.30pm, i need to go home! butr also need some things printing asap so I'll leave it going with then fan 🙂
                            I'll check back tomorrow, thanks for the help
                            Alan 🙂
                            EDIT: ran these again before I go
                            11:28:37 PMM906
                            Motor current (mA) - X:600, Y:600, Z:750, E:1600:0, idle factor 30%
                            11:28:30 PMM913
                            Motor current % of normal - X:100, Y:100, Z:100, E💯100
                            that stepper is still heating up, not sure if it's relevant but it's the one plugged into the driver, not the one plugged into the standard driver
                            EDIT3: 40mm fan is screaming but stepper is getting hotter than I expected... I'll hut the printer down, don't want it to overheat while I'm gone
                              Phaedrux Moderator @alanknight last edited by Phaedrux
                              So I think this was the root of your problem as Veti pointed out. Part of the problem was the period instead of colon, but there's more to it that just that. The command must come earlier in config.g than where you have it.
                              https://duet3d.dozuki.com/Wiki/Gcode#Section_M584_Set_drive_mapping
                              Order dependence
                              M584 must come earlier in config.g than any M350 and M906 commands. If it creates new axes, it must also be earlier than any M92, M201, M203, M208, M350, M566, M574 , M667 and M669 commands.
                              Example
                              M584 X0 Y1 Z2:3 E4:5:6 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 5 and 6 control E motors
                              VERY IMPORTANT! Assigning a drive using M584 does not remove its old assignment. Therefore, if you assign a drive that defaults to being an extruder drive, you should also assign the extruder drives explicitly as in the above example. Failure to do so may result in unexpected behaviour.
                              You need to move your M584 command up above the M350 command. Sorry. I should have caught that sooner.
                              • alanknight
                                no need to say sorry, you're doing me a favour spending your time helping me, I owe you one 🙂
                                edited config file to this...
                                M584 X0 Y1 Z2:3 E4:5 ; Motor remapping for dual Z
                                and
                                AMM906 Motor current (mA) - X:600, Y:600, Z:750, E:1600:1600, idle factor 30%
                                AMM913 Motor current % of normal - X:100, Y:100, Z:100, E💯100
                                I'll give it a go
                                thanks for all the help
                                EDIT: it's about an hour into a print, all steppers nice and cool, thanks again for the help 🙂
                                  Glad that's sorted out.
                                    What was happening is that when the M906 command was executed, the motor connected to E1 output was configured as an extruder, so it got 1600mA. That's why we say that M584 must come before M906. Similarly for M350.
                                    • alanknight
                                      no more hot motors... but I think I've messed something else up, the auto bed leveling doesn't work anymore (or maybe updating firmware broke something?)
                                      to be fair, I was still fine tuning it, I think my bed has sagged a little in the middle, I'm using a buildtac bed (the magnetic one you can lift the tray off) which might throw it off a little too
                                      when I try to run auto bed leveling, or mesh grid leveling the Z comes down, hits the bed and doesn't stop till the motors stall
                                      it doesn't move X/Y at all, here's my config file
                                      M587 S"tripe" P"m580umuu" I192.168.1.89 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                                      ; Define Drives
                                      M208 X200 Y200 Z200 S0 ; Set axis maxima
                                      ;Z-Probe
                                      G31 P400 X40 Y0 Z-4 ; Set Z probe trigger value, offset and trigger height
                                      and bed.g
                                      ; bed.g
                                      ; generated by RepRapFirmware Configuration Tool on Wed Jun 13 2018 17:00:32 GMT+0100 (British Summer Time)
                                      ; Probe the bed at 5 points
                                      G30 P0 X30 Y30 H0 Z-99999
                                      G30 P1 X30 Y185 H0 Z-99999
                                      G30 P2 X185 Y185 H0 Z-99999
                                      G30 P3 X185 Y30 H0 Z-99999
                                      G30 P4 X100 Y100 H0 Z-99999 S
                                      I'm looking again and again, googling etc. but can't figure it out
                                      sorry to keep pestering you guys with questions!
                                      Alan 😮
                                        What type of Z probe are you using? The Z-4 parameter in your G31 line says that it triggers when the nozzle is 4mm below the bed, which surely isn't right. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe to calibrate the trigger height.
                                        • alanknight
                                          IR probe, from the duet3d website
                                          I'll swap that -4 to a 4, that's probably my mistake!
                                          I fell on my head 3 years ago, left me with a bit of brain damage, I make silly mistakes like that and then can't see them no matter how much I look
                                          thanks again for the help, it's printing right now, I'll give it a try when it's finished
                                          Alan 🙂
                                          EDIT: it's still printing, watching it print the z probe reads 535 when it's over what it's printing
                                          I'm thinking that must be the perfect height? - it's reading the high of the last layer it's printing ontop of.... so I can set the z trigger to 535 and z height above nozzle to 0 ?
                                          EDIT: it's not just a Z problem, X moves too far left and crashes into the end stop too... it ignores the end stop and tires to power through
                                          • alanknight
                                            I fixed it...I had z probe offset at 40 when it should have been -40
                                            had to add some Y offset too
                                            thanks
                                            Alan 🙂
