    Solved Under powered stepper motors or something else?
    • cdl1701yahoo.com
      cdl1701yahoo.com last edited by
      Having an issue with an old duet wifi that I have where it seems to be under powering the stepper motors.
      1. list item I cannot get the Z stepper to run two motors like on all the rest of my printers even though I am using the same motors on all. I having to use the E0 stepper for one of the Z motors.
      2. I am using a Nema 14 stepper at 400ma for my extruder but it will not run with any amount of torque. I can grab the motor shaft and stop it from turning with almost no pressure. I thought maybe that I had a bad motor so I hooked up one of my Nema 17s at 1800ma and it does the same thing.
      Nema 14 stepper motor I am using: 14HS10-0404S
      Nema 17 stepper motor I am using: KL17H248-25-4A
      Config:
      ;Endstop Settings*******************************************************************
      M574 X1 Y1 S1 ; Set active high endstops
      ;Z-Probe*******************************************************************
      M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
      M558 P9 H10 F180 T6000 ; Set Z probe type to bltouch and the dive height + speeds
      G31 P25 X25 Y11.95 Z0 ; Set Z probe trigger value, offset and trigger height
      M557 X15:250 Y15:250 S20 ; Define mesh grid
      ;Drives*******************************************************************
      M584 X0 Y1 Z2:3 E4
      M569 P2 S1 ; Drive 2 goes backwards
      M569 P3 S1 ; Drive 3 goes backwards
      M569 P4 S0 ; Drive 4 goes backwards
      M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
      M92 X80 Y80 Z1600 E848.2:E848.2 ; Set steps per mm
      M566 X400 Y400 Z500 E400:400 ; Set maximum instantaneous speed changes (mm/min)
      M203 X30000 Y30000 Z400 E2000:2000 ; Set maximum speeds (mm/min)
      M201 X800 Y800 Z200 E300:300 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1300 E400:400 I30 ; Set motor currents (mA) and motor idle factor in percent
      M84 S30 ; Set idle timeout
      ;Heaters*******************************************************************
      M143 H0 S100 ; Set temperature limit for heater 0 to 100C
      M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      M143 H2 S280 ; Set temperature limit for heater 2 to 280C
      ;M307 H1 A773.8 C240.5 D5.7 B0 ; Set PID Auto tune for H0
      ;M307 H2 A835.3 C250 D4.1 B0 ; Set PID Auto tune for H1
      ;Tools*******************************************************************
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X18 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      ;Network*******************************************************************
      M552 S1 ; Enable network
      M550 P"BOXX" ; Set machine name
      ;M587 S"jupitorstation" P"leamon123" I192.168.0.121 J192.168.0.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ;Fans*******************************************************************
      M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P2 S1 I0 F500 H1:2 T60 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P3 S1 I0 F500 H-1
      • Veti
        Veti last edited by
        @cdl1701yahoo-com said in Under powered stepper motors or something else?:
        M584 X0 Y1 Z2:3 E4
        You are configuring 2 Z axis and 1 Extruder. Yet you are setting the next commands as if you have 2 extruders.
        when you hooked up the other nema motor did you increase the current to match the motor?
        • cdl1701yahoo.com
          Originally I had the configuration set to have two extruders but when I could not get the Z-Motors to run I split them across two stepper drivers.
          So I took out all the sections where I had two extruders set up (EXXX:XXX) and now is just Exxx, that seems to have fixed the extruder problem.
          Now I just need to figure out why my layer cooling fans come on every time the machine is turned on. The come on at 100% and I have to Job Status screen to turn them off.
          • Veti
            Veti last edited by
            because you have told it to turn on at 100% with S1
            • cdl1701yahoo.com
              Man it has been way to long since I have had to edit a config, I am missing some of the most obvious stuff.. lol. Thanks for your help Veti!
