    Change the z offset via gcode
    IR Height Sensor
    • CR3D
      CR3D last edited by
      Hi Friends,
      i use the IR Probe and everything works fine.
      a thing bothers me but still ... the change of the offsets at nozzle change.
      Is it possible to change the z offset also incrementally (for example +0.05 or -0.05 or other values) e.g. by GCode?
      So similar to the babystepping, only the offset value is stored permanently.
      I would like to implement this without having to change the value in the config because my users the printer can not change the firmware.
      As a user interface I use a Raspberry Touch with repetier server.
      I would be very happy about an answer!
      Thank you!! 🙂
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
        You could use a macro that automates measuring the G31 z offset using G30 S-3 and use M500 P31 to save it to the config-override.
        https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
