    Fans are not driven correctly
    • SmOkE
      SmOkE last edited by
      Hello everybody,
      I use a hotend fan and a component fan on my delta. The hotend fan is on P0 and is temperature controlled. He starts at 45 °. That works perfectly too.
      The component fan should be controlled by the g-code. He will not. According to the file, the fan should start from the third layer. He stays out, why?
      Via the DuetLocal interface I can control both fans promlemeless manually. In the config.g I have deposited the following.
      M106 P0 S0 I0 F500 H1 T45; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is on
      M106 P1 S0 I0 F500 H-1; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
      Greetz Marcus
      • Veti
        Veti last edited by
        you want to switch them around
        the fan0 should be the part cooling and fan1 should be the thermostatic fan.
        otherwise you will need to assign that fan to your tool using M563.
        • SmOkE
          So I just plug the fans over?
          • Veti
            Veti last edited by Veti
            and swap p0 and p1 in the m106
            • SmOkE
              Ok, that's certainly the simple variant or? How would it go with the m563 command please?
              • Veti
                Veti last edited by
                https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
                Change your M563 line and add a F1 i think
                • SmOkE
                  Hi, it worked 🙂 Thank you very much for the help
                  greetz marcus
