    Possible Reprap Configurator Bug
    rrf config tool
    • cookie
      cookie last edited by cookie
      It seems like I can't continue after adding heated bed in Reprap configurator, both happened in Chrome and Firefox latest version. It works when I unchecked heated bed.
      Possible bug? or I did something quite not right here? @chrishamm
      Thanks,
      Cookie
      • chrishamm
        chrishamm administrators last edited by chrishamm
        Did you do anything particular? I cannot reproduce this problem.
        Duet software engineer
        • chrishamm
          @cookie I just cleared the site's cache after my latest updates. Please try to reload the page, enter your config again and confirm that the problem still exists.
          cookie 1 Reply Last reply Reply Quote 0
          • cookie
            cookie @chrishamm last edited by
            @chrishamm I already found that the problem occurs only when I loaded an existing configuration, which was previously saved with heated bed 'unchecked'.
            Also, I've noticed that the Semitec 104-GT2 value is confusing. The preconfigured in RFF is β: 4388 K while the Wiki stated it is 4725 K here.
            Thanks,
            Cookie
            • chrishamm
              Thanks, I'll fix the beta value again - looks like I undid a fix I made a while ago. 4725K should be correct with that C value and 4388K seems OK without the C value.
              Can you upload your config.json so I can try to reproduce the bug on the heaters page? I tried to reproduce the problem you reported but it worked for me.
              Edit: The Semitec thermistor values are fixed again.
