    Multiple Z motor wiring
    • hussainsail2002undefined
      hussainsail2002
      I have been planning to build a large 500X500 machine.
      For the Z axis I am planning to use 4 nema 17 stepper motors to lift the X Y gantry and keep the Build platform stationary.
      Is it a good idea to connect all 4 motors to a single driver by connecting in series
      or is it better to use 4 different drivers. ?
      The main issue I foresee is that the Z axis lead screws can go out of sync and bind.
      I do not want to add belts and pulleys for the Z unless its necessary, also the load I will be carrying is under 4 Kgs
      Any suggestions would be helpful.
      Thanks
      Hussain
      • Vetiundefined
        Veti
        use 4 different driver and use
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        • Vetiundefined
          Veti
          also the ideal size is 3 motors.
          see
          https://drmrehorst.blogspot.com/2017/07/3-point-print-bed-leveling-vs-4-point.html
            hussainsail2002
            Hi ,
            Thanks for your reply.
            Do you think there is any chance for the drivers to go out of sync and cause a binding issue.
            I am assuming that this is the main reason why people use a belt and pulley to run multiple lead screws.
            • Vetiundefined
              Veti
              that depends on the lead screws and nuts used.
              the normal 8mm lead screws and nuts have quite some play on them.
              given that the steppers can go 2 full steps out of sync
              1.8 motor 200 steps per rev.
              1/100 rev out of sync.
              assuming one goes up one down
              2/100 revs out of sync.
              normal lead scews 8mm per rev
              8mm*2/100=0.16mm out of sync
              which should be fine for normal lead screws.
              hussainsail2002undefined 1 Reply Last reply Reply Quote 0
                hussainsail2002 @Veti
                @veti
                Thanks A lot will try with different drivers first and let you know how it goes.
