    IDEX printer, 2nd extruder stuck at original layer height
    • tstarkengineering
      tstarkengineering last edited by
      IDEX printer,
      First layer everything looks great. 2nd layer and beyond, 1st extruder keeps changing per designated layer height, 2nd extruder stays at original layer height.
      After 10 layers or so. 1st extruder is on layer 10, 2nd extruder is trying to lay down layer 10 at layer 1 or 2 height
        Which electronics and firmware are you using?
        • tstarkengineering
          Ill check on the firmware version but one of the fairly newest.
          Duet wifi
          5x
          Bl touch
          Been playing around with g31, and g10 on both extruders
          • tstarkengineering
            Opps duet 2 wifi
              Do you have a large Z offset configured for one of your tools in G10?
              • tstarkengineering
                tstarkengineering last edited by tstarkengineering
                Actually no. Now i tried again and now skirt lays down perfect layer on both extruders, then layer 1 is now 2mm above build platform
