    USB socket pulled off the board
    • Colin Kentundefined
      Colin Kent
      Unfortuneatly I left the USB plug connect to mt DUEt2 wifi. When I moved the gantrey the lead got caught and pulled USB socket almost off the to an angle of 90 degrees. Ive pushed it flat again but it no longer connects. Is there any way I can get this repaired ?
      Martin1454undefined 1 Reply Last reply Reply Quote 0
      • Martin1454undefined
        Martin1454 @Colin Kent
        @colin-kent depending on how good you with a soldering iron and how bad the traces/pads for the usb is damaged.
        Colin Kentundefined 1 Reply Last reply Reply Quote 0
        • A Former User?
          A Former User
          The biggest problem with repairing such a thing is without the pads to anchor the port it will be quite weak.
          Clean up the port and board, remove solder mask from traces, solder wires from port to traces, epoxy port in place. Fiddly work, but absolutely doable.
            Colin Kent @Martin1454
            I Have found the socket on RS. I have the tools, not sure about my eyesight but will have a go I think
