    Header Part Numbers
    • Edumaundefined
      Eduma
      Does anyone know the part number for the 50 pin expansion header and the CONN_SD header. I need to land a custom custom cables and I'm looking to source the correct mating connector. The connectors I have are loose and do not seem to provide a good connection.
        There are lots of equivalent parts for that connector. Here's one: https://uk.farnell.com/multicomp/mc-254-50-00-st-dip/connector-header-50pos-2row-2/dp/2843537. And here's an example of the mating ribbon cable connector: https://uk.farnell.com/3m/d89150-0131hk/connector-rcpt-50pos-2row-2-54mm/dp/2672519.
