    Clean install to sd
    • BearcatTD
      BearcatTD last edited by
      Hello all,
      After two plus weeks of smooth sailing, I went to turn on the printer, login and I got the web connection error. I found a forum post that suggested a bunch copying and renaming files on the sd card and I fear that I have right hosed the install. Is there a file floating out there that I can flash to a clean SD card and start over? I've backed up all of my config files, but right now the sd card is a hot mess.
      Thanks in advance for any help!
      Pat
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
        There's nothing to flash to the SD card itself. It just holds the config files, macros, and gcode files. The firmware itself gets flashed to the board and only stays on the SD card as a backup.
        If you want to start fresh with the card here's what I suggest.
        Format the card using this tool: https://www.sdcard.org/downloads/formatter/
        Then create the following folders
        gcodes
        macros
        sys
        www
        Place your backed up config files into sys.
        Hopefully you backed up any custom macros too, they go into macros
        Then download the latest DWC files you want to use and extract the zip file into the www folder.
        That should get you up and running.
        https://duet3d.dozuki.com/Wiki/Firmware_Overview#Section_SD_card_structure
        • BearcatTD
          Thanks! Worked like a charm!
