    Heater Fault
    390
    • pcsentinel
      pcsentinel last edited by
      Hi, My DuetWifi is showing a permanent fault on heater 1 as per the attached PNG. I have measured the resistance of the heater 1 thermistor and it reads 159kOhm. Just in case, also checked the heater 2 thermistor which is showing 157KOhm and the Bed which is showing 158KOhm
      The above measurements were taken at the board end of the cables.
      I have attached diagnostic and setup files.
      1_1557818613624_K8200Duet Fault Diag.txt 0_1557818613624_K8200Duet Fault config.txt
      • Veti
        Veti last edited by
        post your config
        • pcsentinel
          I have, its linked in the message under the picture.
          • Veti
            Veti last edited by
            the config looks ok.
            did the temperature work before?
            you are running a very old version of the firmware (1.2) consider updating to the current version 2.02
            • pcsentinel
              Everything has been working fine for a long time, I was printing fine yesterday, but after the print had ended this fault just presented itself. I have obviously tried switching the unit on and off multiple times, but it always comes up with the error. I know the FW is old, but since its been working fine, I don't think its related
              • Veti
                Veti last edited by
                could be a blown vssa fuse.
                • Veti
                  Veti last edited by
                  disconnect all and connect one at a time to rule out shorting of the vssa line.
                    dc42 administrators @Veti last edited by dc42
                    @veti said in Heater Fault:
                    Yes, if your Duet is a revision 1.0 or 1.01 then with power off, use a multimeter to measure the resistance between VSSA on a thermistor pin and GND on an endstop pin. It should read no more than a few ohms. If instead it's very high, the VSSA fuse has blown, which will make all thermistors read 2000C.
                    • pcsentinel
                      Its a V1.01 board and that measurement is 60KOhm so guess the fuse has blown
                        dc42 administrators @pcsentinel last edited by
                        @pcsentinel said in Heater Fault:
                        Yes. Find and fix the short between thermistor wiring and something else that probably caused it to blow, then see https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers#Section_VSSA_fuse for how to replace or bypass the fuse.
                        • pcsentinel
                          Thanks for your help, have now applied full resettable fuse and 10K resistor fix. Funny though as could not find original fault.
                          Whilst fixing I have also recognised a further issue but as is unrelated I have created a new thread.
                          • felixlvh
                            felixlvh last edited by felixlvh
                            Hi @dc42, i have the same issue as mentioned above. can you eleborate how can i use a multimeter to verify if i have vssa fuse blown? i am pretty sure all wiring are ok and now i am getting open circuit error message. thanks a ton!
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.05.1 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2020-02-09b1
                            @dc42 said in Heater Fault:
