    Big Sized Printer Mesh Bed Leveling & Lead screw Adjustment
    371
    • Pradeepkumar
      Pradeepkumar last edited by Pradeepkumar
      I am trying to level the bed. My homing works good. Below you can find my home, config and Bed files.
      2_1557836453004_Home all.txt 1_1557836453004_Config.txt 0_1557836453004_bed.txt
      Printer Setup
      I have four lead screws for four Z motor, however two are in series, hence only two drivers. I have two individual drivers for Y axis for two motor. And one X axis motor. Lead screw is from Igus - DST­LS­10X12­R­1100­ES
      Moveable area that is the maximum and minima of the printer is about X 610, Y635 and Z 950. But, I have bed size of 500*500 mm.
      My issues
      1. G32 is not running according to the bed file, whenever called it goes to X0 Y0 instead of X50 Y30. I tried even with G90 still it goes to X0 Y0.
      2. Same happening with G29
      3. Is necessary to give the lead screw adjustment in the config file, but I have not declared. Because it is away from my print area
      4. In homing all, when M584 P3 used, it does not work as expected. I have removed the same and it works well. Though I combining the Y axis the axis, but, I still see the extra u axis.
      Your help is highly appreciated.
        M208 X0 Y0:0 U0 Z0:0 V0 S1 ; Set axis minima
        M208 X610 Y635:635 U635 Z950:950 V950 S0 ; Set axis maxima
        You've used a mixture of old and new M208 syntax. Try changing this to either:
        M208 X0 Y0 U0 Z0 V0 S1 ; Set axis minima
        M208 X610 Y635 U635 Z950 V950 S0 ; Set axis maxima
        or this:
        M208 X0:610 Y0:635 U0:635 Z0:950 V0:950 ; Set axis minima and maxima
        • Pradeepkumar
          @dc42 said in Big Sized Printer Mesh Bed Leveling & Lead screw Adjustment:
          or this:
          @dc42 : Thanks for the quick reply.
          I have tired both, first one works with homing, but the mesh bed again goes to x0 y0 instead of X50 Y30. But the second one does not work for homing also because it may be missing a syntax (since it going on the opposite z direction).
            Which firmware version are you using?
            • Pradeepkumar
              2.0(RTOS) (2018-06-05b3)
                dc42 administrators @Pradeepkumar last edited by
                @pradeepkumar said in Big Sized Printer Mesh Bed Leveling & Lead screw Adjustment:
                OK, that's an old firmware version that doesn't support the new M208 syntax. Please upgrade to 2.02 or 2.03RC2.
                • Pradeepkumar
                  Does it affect the mesh bed leveling with G32, if so please send the link for updating the firmware, firmware with less bugs. Also if there a link on how to please share the same as well.
                    Here the link for 2.02: https://github.com/dc42/RepRapFirmware/releases/tag/2.02. Read the "Upgrade notes" sections in https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md for releases 2.02 and 2.02, to see if you need to change anything in your configuration files.
                    • Pradeepkumar
                      I have upgraded to firmware 2.03RC2 (2019-05-14b2), But the mesh bed leveling is again going to X0 Y0. I think there might be other things to be changed. My issue is not with the minimum and maximum. The G30 P0 X50 Y30 H0 Z-99999 is going to X0 Y0 instead of X50 and Y30
                      • Veti
                        Veti last edited by
                        it probes point X50 Y30
                        since that is your probe offset the position of the head is at X0 Y0 where it can probe X50 Y30.
                        Pradeepkumar 1 Reply Last reply Reply Quote 0
                        • Pradeepkumar
                          Pradeepkumar @Veti last edited by
                          @veti Thanks for the comment, I did not know that G31 is for probe offest as well, I have changed, Now it works well. Thanks once again for help. Do you have suggestion for my comments below.
                            dc42 administrators @Pradeepkumar last edited by dc42
                            It's normal for the leadscrew coordinates that you specify in the M671 command to be outside the printable area.
                            The homeall.g file that you posted doesn't have the M584 P3 command. Where in that file did you try using it?
                            • Pradeepkumar
                              Pradeepkumar @dc42 last edited by
                              @dc42 Hi I am using the M584 Y1:3; Joining the Y&Z axis, if i use M584 Y1:3 P3; Joining the Y&Z axis, is not joining the coordinates.
