    The usual doubt ... fans
    • peirof
      peirof last edited by
      Well...
      after the issues with the fuse, i have changed 2 fans, think they are problematic...
      But.... I can not configure them
      I have 3 fans, 1 to Heatskin and 2 layers fans:
      The HEATSKIN fan are conected to Duet Board, in Fan0 Socket, and layer FANS are connected to FAN1 and FAN2.... This the phisical connections.
      In Config.g, i have:
      ; GCODE FAN
      M106 P0 H-1; Layer 01
      M106 P1 H-1; Layer 02
      M106 P2 S1 I0 T40 H1; El del Heatskin
      The problem.... something its wrong
      When i restart Duet... 1 layer fan, power on, the other NO.
      When try to calibrate temperature, Heatskin fan DONT power on.
      By DWC, i can power on/off all 3 fans.
      I have erased config.old.
      Whats wrong?
      • Veti
        Veti last edited by
        did you map all the fans to the tool?
        see
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
          dc42 administrators @peirof last edited by
          @peirof said in The usual doubt ... fans:
          You haven't included S0 in that command to make sure that the fan is turned off.
