    Can't find the correct wiring diagram for a Duet 0.6 board.
    • sLpFhaWK
      sLpFhaWK last edited by
      I'm going to be putting is this old Duet into a Mini Kossel and replacing the smoothieboard.
      It's been a while since I used it, but I cannot find a pinout for the board that isn't showing a 0.8.5 board, even on the wiki.
      I have XYZ E0 heated bed, FSR and PArt fan.
      I think the HE Fan just gets wired to 12v so it's always on, which isn't an issue. Does the part fan get wired to Fan0? Where does the FSR connection go, next to E0 using the E1 set of pins?
      Thanks!
      -sLpFhaWK
      Ultibots K250v
      Rostock Max v2 Soon to be Full MetalMax
      Mini Kossel
      • Dougal1957
        Dougal1957 last edited by
        https://reprappro.com/wp-content/uploads/2014/05/ORM2-528.5-Duet0.6-109-v1.png
        • sLpFhaWK
          Thanks, but FSR's aren't a proximity based sensor, and I had it wired up before I just forget how i had it. I didn't know I could wire the 12v to those pins though, so thats a bonus.
          -sLpFhaWK
          Ultibots K250v
          Mini Kossel
          • sLpFhaWK
            I think I just found my answer,
            If using JohnSL's trinket board: Connect its Vcc, Output and Ground pins to 3V3, STP and GND respectively on the E0 endstop connector, and select mode 4. Alternatively, connect them to 3.3V, IN and GND on the Z-probe connector and select mode 5.
            -sLpFhaWK
            Ultibots K250v
            Mini Kossel
