    bltouch and how to auto level bed?
    • twistedechos
      twistedechos last edited by
      hello guys so i just put my duet 2 wifi on my tevo tornado with some help from a really cool guy of the tornado facebook group but im not sure how to get the auto bed leveling to work its the last thing i have to do before i can print any help would be great here is my config.g
      ; generated by RepRapFirmware Configuration Tool v2 on Wed Apr 03 2019 15:50:04 GMT-0500 (Central Daylight Time)
      M550 P"PrinterOfThings" ; Set machine name
      M552 S1
      M552 P10.0.20.25
      M554 P10.0.1.0
      M553 P255.255.0.0 ; Enable network
      M586 P0 S1 ; Enable HTTP
      ;M586 P1 S1 ; Enable FTP
      ;M586 P2 S1 ; Enable Telnet
      M569 P0 S0 ; Drive X goes Backwards
      M569 P1 S0 ; Drive Y goes Backwards
      M569 P2 S1 ; Drive Z goes Forwards
      M569 P3 S0 ; Drive E goes Backwards
      M92 X80.00 Y80.00 Z400.00 E412.6 ; Set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X200.00 Y200.00 Z100.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X900.00 Y900.00 Z900.00 E900.00 I10 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y0 Z-20 S1 ; Set axis minima
      M208 X300 Y300 Z400 S0 ; Set axis maxima
      M591 D0 P1 C3 S1 ;sets filament out sensor Extruder 0 P2 switch type high = out c 3 extruder limit 0
      ;M591 D1 P1 C4 ;sets filament out sensor Extruder 1 P2 switch type high = out c 3 extruder limit 0
      M574 X1 Y1 S0 ; Set active low and disabled endstops
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      ; BLTouch - Heaters
      M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
      M557 X15:285 Y15:285 S50 ; Define mesh grid
      M558 P9 H5 F100 T6000 A5 R0.2 ; P9 for BLTouch, dive height 5mm, probe at 100mm/min, travel 6000mm/min, up to 5 probes, pause 0.1s
      G31 X-45 Y-5 Z0.350 P25 ; probe XY offset and Z trigger height and trigger value
      M557 X5:300 Y5:300 S50 ; Define mesh grid
      M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      M143 H1 S265 ; Set temperature limit for heater 1 to 265C
      M106 P1 S0 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      • PaulHew
        PaulHew last edited by
        In the web page for your duet board, DWC, click the Auto Bed Compensation
        0_1558126523444_d3733dfd-ac02-449a-8f59-55dea6c05e0e-image.png and if you click the button it will probe the bed.
        From the dropdown you can configure the grid.
        Make sure in your slicer you include 'G29 S1 ; Get mesh' in your start GCode.
        HTH
        Paul
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
        • twistedechos
          ok thank you so now im having a problem with my bltouch it seems to stutter when i probe the bed as if there is a voltage drop on the magnet in it or something so it gives me an error Error: Z probe readings not consistent
