    Duet2 WiFi + MAC / M587: Bad or missing param / Terminal funk
    • nurbie
      nurbie last edited by
      There's a locked post from earlier for:
      M587: Bad or missing parameter
      Duet Getting Started statements are pretty straightforward but they don't say: USE COURIER (font)
      Particularly for the quote marks in SSID/PASS assignments!
      I had similar problems as past offenders, but the font and formatting got me going.
      Easy to overlook!
      Essentials:
      ls /dev/tty.*
      will generate:
      /dev/tty.Bluetooth-Incoming-Port /dev/tty.usbmodem123
      /dev/tty.Bluetooth-Modem /dev/tty.usbmodem456
      you will enter one of those # as:
      screen /dev/tty.usbmodem123 115200
      or
      screen /dev/tty.usbmodem456 115200
      M115 // may do something for you!
      M552 S0 // set wifi to idle
      M587 S"your SSID" P"pass" // SSID / PASS
      M552 S1 // enable wifi
      Will generate some lines like this:
      WiFi module is idle
      WiFi module is connected to access point YOUR_SSID, IP address 192.168.43.224
      Your WiFi on the DUET should light up and stay on
      Take that IP and run it in a browser
      BAM!
      Follow the Duet3D steps to confirm the config.g has the M552 S1 in the first few lines.
      You're G2G
      remember the font
        I see that https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7?lang=en#s8 has been updated to cover this.
        • nurbie
