    Sensorless Homing Not Working Anymore
    delta homing sensorless
    • zzing
      zzing last edited by
      I have configured my printer to use sensorless homing. I was experience some issues where sometimes one of the towers might not actually move the motor - as if it had detected something without even moving. I was trying some tweaking and now the belt just vibrates when it hits the hard plastic stopping block. Note that I have verified the motor isn't spinning anymore, it is just the belt is vibrating. So I haven't been able to figure out what is actually going on and why it isn't detecting the stop.
      Unfortunately, I didn't end up keeping my original config, but it seems to be the same so far as I remember.
      Some notable points from my config:
      M574 X2 Y2 Z2 S3
      M915 X Y Z F0 S3 H200 R0
      and from my home delta:
      G91                       ; relative positioning
      M400
      M913 X25 Y25 Z25
      G1 H1 X300 Y300 Z300 F1800 ; move all towers to the high end stopping at the endstops (first pass)
      G1 X-5 Y-5 Z-5 F1800 H2   ; go down a few mm
      G1 H1 X10 Y10 Z10 F360    ; move all towers up once more (second pass)
      G1 Z-5 F6000              ; move down a few mm so that the nozzle can be centered
      G90                       ; absolute positioning
      G1 X0 Y0 F6000            ; move X+Y to the center
      M913 X100 Y100 Z100
      I have tried various amounts of current %, filtered and not, sensitivities (even down to -10), etc.
      Any suggestions would be helpful.
      carlosspr 1 Reply Last reply Reply Quote 0
      • carlosspr
        carlosspr @zzing last edited by carlosspr
        @zzing I remember to have had some issues when speed was too low.
        In my settings I have F2000. For the rest, the settings seem OK to me if the 25% current allows you to move the drivers (my minimum was 35% and below that it would fail).
          As @carlosspr says. For stall detection to work, the feed rate in your G1 S1 commands must be at least (60 * m915-h-value / full-steps-per-mm) . If your printer has 80 steps/mm @ x16 microstepping, that's 5 full steps/mm. You are using H200 in M915, so the minimum G1 S1 feed rate would be (200 * 60)/5 = 2400.
          • totalitarian
            totalitarian last edited by
            This post is deleted!
