    SOLVED DUET WiFi E0 / E1 no workie - config?
    497
    • nurbie
      nurbie last edited by nurbie
      RMAX V3
      DUET WiFi 2.02 firmware
      XYZ + endstops/homing all work perfectly
      PREFACE, I did fudge with the config, adjusted steps to 80, and deleted anything heated/thermistors, bed, and hot-end.
      Not extruding anything heated.
      The BIG DEALio (fail):
      The extruder stepper itself is connected to the E0 section, but it doesn't energise/show an LED, and the DUET WiFi interface has the Extruder controls grayed out and inaccessible:
      I have tried 2x other steppers and none of them seem to respond/show a connection to the Duet in either E0 or E1 positions.
      E0 and E1 steppers don't energize/connect
      wiring is correct/tried multiple steppers on both E0 and E1
      It must be my n00b-modified config.g
      Can you see what I'm missing? (config below)
      M550 PODWOOD_CLAY_01 ; Printer name
      M555 P2 ; Gcode Output Type
      M552 S1 ; Enable Wifi
      G21 ; Work in millimeters
      G90 ; Send absolute coordinates
      M569 P0 S0 ; Drive 0 goes forwards (X)
      M569 P1 S0 ; Drive 1 goes forwards (Y)
      M569 P2 S0 ; Drive 2 goes forwards (Z)
      M569 P3 S0 ; Drive 3 goes forwards (E0)
      M569 P4 S0 ; Drive 4 goes forwards (E1)
      M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
      M665 R144 L291.06 B135 H375 X0 Y0 Z0 ; delta radius, diagonal rod length, printable radius and homed height
      ; Y X Z are tower angle offsets
      M666 X0 Y0 Z0 ; endstop offsets in mm
      M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping w/ Interpolation
      M92 X80 Y80 Z80 ; Set axis steps/mm
      M92 E400.0:400.0 ; Set extruder steps/mm
      M906 X1200 Y1200 Z1200 E1200:1200 I50 ; Set motor currents (mA) and idle current %
      M201 X4200 Y4200 Z4200 E5000 ; Accelerations (mm/s^2)
      M203 X15000 Y15000 Z15000 E15000 ; Maximum speeds (mm/min)
      M566 X2000 Y2000 Z2000 E2000 ; Maximum instant speed changes mm/minute
      M106 P0 H-1 ; Part Cooling Fan
      M106 P1 S0.5 H-1 ; Case fan
      M106 P2 T50 S0.7 H1 ; Heat sink fan
      M558 P5 I1 X0 Y0 Z0 H15 F200 ; FSR Settings
      G31 P500 X0 Y0 Z-0.3 ; Probe trigger value and offsets
      M270 I1 P1 S0.05 ; Enabled Probe doubletap w/ 0.05mm tolerance
      M557 R140 S30 ; default bed mapping
      M501 ; Load saved config values
      T0 ; Select Tool 0
      M302 ; COLD EXTRUSION
      M375 ; Load height map
      My JohnSL FSR board doesn't seem to respond at the DUET board either; it's properly sensing and the wiring is correct per the DUET2 instructions/wiring diagram...
      • rodek
        rodek last edited by
        for the extruder to work the hot end must be 160deg or you could use a M302 to allow for cold extrusion.
        • nurbie
          Yes, this machine will be doing cold extrusion exclusively.
          Where would I enter the M302 value?
          • DocTrucker
            DocTrucker last edited by
            Put it at the end of your configuration file.
            Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
            • nurbie
              XYZ steppers appear to be energised and have LEDs on.
              That, and I know they work since I can control them through the GUI.
              Does the LED for E0 / E1 only light up if extrusion is called for in gcode?
              How can I test the E0 / E1 steppers to know that they are working /wired correctly?
              Is there some gcode I can load to test them?
              A Former User 1 Reply Last reply Reply Quote 0
              • A Former User
                A Former User @nurbie last edited by A Former User
                @nurbie said in DUET WiFi E0 / E1 no workie - config?:
                LEDs are for the ends stops (and the two other E0/E1 leds are for the FETs)
                • nurbie
                  How do I control them through the GUI/terminal?
                  Any tests/ideas?
                  • A Former User
                    A Former User last edited by
                    If you were to look up the M302 command you'd find you also need to specify which extruder to allow cold extruding for.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
                      dc42 administrators @nurbie last edited by
                      Any tests/ideas?
                      Select a tool that has an associated extruder. Either set that tool to have no associated heaters in your M563 tool definition command, or enable cold extrusion. Then the extruder buttons in DWC won't be greyed out.
                      • nurbie
                        YES! Gracci dc42!
                        M563 P0 D0 S"LDM_01" did the trick! now testable via GUI.
                        Should there be a Duet LED (proximate to the connector like XYZs) showing that the E0 is energized?
                        M302's not sure if they made any changes but added them as backup.
                        NOW, on the getting the FSRs recognized by the Duet . . . (that's another forum post)
                        M563 P0 D0 S"LDM_01" ; create a named tool using extruder drive 0
                        M558 P5 X0 Y0 Z0 H15 F200 I1 ; FSR Settings
                        T0 ; Select Tool 0
                        M302 ; Report current state
                        M302 P0 ; Allow cold extrusion
                        • A Former User
                          Only if the heater or endstop is active.
                          • nurbie
                            thanks m8
