    DUET 2 WiFi FSR no workie - config?
    • nurbie
      nurbie last edited by nurbie
      My FSR trinket isn't talking to the DUET2 WiFi.
      JohnSL board and FSRs all signal properly;using my finger lightly on the build plate the trinket red LEDs light up correctly/individually/averaged depending on pressure location.
      Should I see anything blinking on the DUET board, or see the Z-probe GUI change?
      Z-probe GUI always reads 0
      Wiring to the Z-probe connector is correct according to DUET Z-probe wiring diagram.
      Using the OEM GreenBlackRed assignments for the JohnSL
      FSR board is wired to Duet z-probe as:
      I've tried running g30 and tapping the deck, and switching the wiring between GND and IN. Red wire has remained 3.3v(?)
      The JohnSL trinket lights up as it should, hotspots/averaged, but that signal doesn't halt the g30 as it should so I shut the thing down and try again.
      Ran g32
      effector tracked down to bed,
      moved to Z periphery,
      slowly lowered to trigger FSR - FSR showed contact(lit up)
      crashed build plate until I emergency aborted(but not before the effector was tweaking arms and effector plate joints ...)
      FSRs just aren't talking to DUET.
      nothing registers in GUI; shouldn't I be seeing a response here(Z-probe) when manually/other triggering the FSRs?:
      Not sure what else to do
      latest config: (FSR@bottom)
      M550 PODWOOD_CLAY_01 ; Printer name
      M555 P2 ; Gcode Output Type
      M552 S1 ; Enable Wifi
      G21 ; Work in millimeters
      G90 ; Send absolute coordinates
      M569 P0 S0 ; Drive 0 goes forwards (X)
      M569 P1 S0 ; Drive 1 goes forwards (Y)
      M569 P2 S0 ; Drive 2 goes forwards (Z)
      M569 P3 S0 ; Drive 3 goes forwards (E0)
      M569 P4 S0 ; Drive 4 goes forwards (E1)
      M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
      M665 R144 L291.06 B135 H375 X0 Y0 Z0 ; delta radius, diagonal rod length, printable radius and homed height
      ; Y X Z are tower angle offsets
      M666 X0 Y0 Z0 ; endstop offsets in mm
      M350 X16 Y16 Z16 E16:16 I1 ; Set 16x microstepping w/ Interpolation
      M92 X80 Y80 Z80 ; Set axis steps/mm
      M92 E400.0:400.0 ; Set extruder steps/mm
      M906 X1200 Y1200 Z1200 E1200:1200 I50 ; Set motor currents (mA) and idle current %
      M201 X4200 Y4200 Z4200 E5000 ; Accelerations (mm/s^2)
      M203 X15000 Y15000 Z15000 E15000 ; Maximum speeds (mm/min)
      M566 X2000 Y2000 Z2000 E2000 ; Maximum instant speed changes mm/minute
      M106 P0 H-1 ; PART-DRYING FAN
      M106 P1 S1 H-1 ; DUET CPU fan
      M106 P2 T25 S100 ; LDM fan
      M563 P0 D0 S"LDM_01" ; create a named tool using extruder drive 0
      M558 P5 X0 Y0 Z0 H15 F200 I1 ; FSR Settings
      G31 P500 X0 Y0 Z-0.3 ; Probe trigger value and offsets
      M270 I1 P1 S0.05 ; Enabled Probe doubletap w/ 0.05mm tolerance
      M557 R140 S30 ; default bed mapping
      M501 ; Load saved config values
      T0 ; Select Tool 0
      M302 ; Report current state
      M302 P0 ; Allow cold extrusion
      M375 ; Load height map
      I'm thinking there's some config like M581: Configure external trigger or M585: Probe Tool (?) that I need to mess with to have the Z-probe get initialized?
      What does this do?
      • nurbie
        This post is deleted!
        • nurbie
          SOLVED
          That is, on a Rostock Delta Max V3 running JohnSl FSR kit
            Strange, your first photo looked correct to me.
            • nurbie
              Yes, the wiring diagrams I saw clearly are the first layout.
              Then I found one that had some color-blindness going on,
              but got me there:
              It states:
              Grey is the Signal, red is 3v3 and black is ground
              (this is not my board/trinket)
              I was convinced 'gray'(my red) is 3.3v, because the board was getting power and working/sensing/lighting up the correct LEDs.
              Right?
              I just stared at my config and thought,"what could possibly go wrong? I might fry a $7 (USD) part, but ...
              MAGIC COULD HAPPEN"
              I mean,
              SCIENCE COULD HAPPEN!
              and there was much rejoicing
              • ultibots58
                ultibots58 last edited by
                Nurbie , I'm having similar problems .
                Your solved photo shows the connections at the duet end.
                What are your connections at the FSR end ?
                Is red wire connected to signal on fsr board and at Duet end to Z Probe In ?
                My confusion stems from this paragraph in the duet dozuki:
                If using JohnSL's trinket board: Connect its Vcc, Output and Ground pins to 3.3V, IN and GND on the Z-probe connector respectively and select mode 5.
                John's board does not have Vcc , Output or Ground labels on the 3 pins in the corner of the board.
                They are labelled: Signal , -/+ , +/-
