    Bed PID tuning
    • Exerqtor
      Exerqtor last edited by Exerqtor
      Just switched the bed to PID as supposed to BangBang since i've got it hooked up to a external mosfet and a dedicated 24V 400w PSU (the rest of the machine runs on 12V).
      At the end of the tuning i got this messange (in "warning yellow") :
      "Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 220C.
      Auto tune heater 0 completed in 1176 sec
      Use M307 H0 to see the result, or M500 to save the result in config-override.g"
      Should i pay any attention to this? Can't really find anything about the subject anywhere.
      • A Former User
        A Former User last edited by
        Its just a warning telling you that you tuned the bed to a temperature significantly lower than what would be the expected steady state temperature in case of a failure leaving the bed powered on outside of the control loop. (which shouldn't happen).
        So its up to you to consider if in the unlikely scenario of a failure if 220C would pose a problem, or take measures to prevent 220C from being a possibility. (thermal fuse, lower voltage, screw connections with no flamable parts near the bed, etc)
        Exerqtor 1 Reply Last reply Reply Quote 0
        • Exerqtor
          Exerqtor @Guest last edited by Exerqtor
          @bearer
          That's what i kinda suspected, but isn't that just as likely to happen when/if it's running BangBang?
          • A Former User
            Possibly, but maybe the bit-bang tunign isn't able to predict the steady state temp?
