    Z stop not working during homing
    • James
      James last edited by
      Using a Duet Wifi, my Z stop works electrically. The light on the board comes on if you manually click the switch, and M119 reports the correct information. But then if I home the printer (a delta, so all 3 axis move at once), the X and Y endstops work, while the carriage repeatedly bangs into the Z stop until power is removed.
      This occurred after having the printer down for a while and installing 0.9 degree motors. Now when I hook it back up, I can't get past this homing issue. I can't see what this would have to do with the new motors – just mentioning it just in case.
      Anyone have suggestions?
      And side question: How does the Duet Wifi know it's connected to a delta and not a cartesian? (I was thinking that perhaps it doesn't know and this is somehow causing the problem).
      • T3P3Tony
        Double check your configuration against this page:
        https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_Delta_printer
        You can also use the configurator as a start point:
        https://configurator.reprapfirmware.org/
        If the endstop is otherwise working (looks like it is by your description) then an incorrect delta configuration sounds likely.
        Duet Hardware Designer
        www.duet3d.com
          The Duet WiFi only knows it is connected to a delta when it sees the M665 command in your config.g file. A tell-tale sign is that PanelDue and DWC show 1 homing button instead of 4 when the firmware informs them that it is running on a delta. Also in DWC the bed compensation button gets renamed to "Auto delta calibration".
          • James
            Hmmm… It already knows it is a delta then, both because of the interface difference and I see the M665 command. Below is an excerpt from config.g.
            I'm sure axis steps/mm is wrong since I did not update for the 0.9 degree motors, so I'm guessing it is moving things half as fast as it thinks, but I wouldn't think that would cause a problem.
            I'm going to change steps/mm to 160 (assuming that is the correct value for a 16 tooth pulley using GT2 belt), and reduce the currents if for no other reason that when it bangs into the end and tries to keep going, I want it to do that more gently.
            Beyond that, any troubleshooting suggestions?
            M665 R114.0 L221.5 B75 H255 ; set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
            M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
            M92 X80 Y80 Z80 ; Set axis steps/mm
            M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
            M201 X500 Y500 Z500 E1000 ; Accelerations (mm/s^2, default is 1000 for XYZE)
            M203 X10000 Y10000 Z10000 E3600 ; Maximum speeds (mm/min, default is 20000 for XYZ)
            M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
              For a 16 tooth GT2 pulley with 0.9deg motors and x16 microstepping, there are 200 steps/mm. 160 would be right for a 20 tooth pulley.
              Please post your homedelta.g file.
              • James
                Fixed, one of the endstops was cross wired so that the Z endstop was on the X connector.
