    Duet3D PCB delta printer effector sneak preview
    53
    367
    78.0k
    • Whitewolfundefined
      Whitewolf
      @dc42:
      The PCB effector uses two connectors, one for signal wires and one for power wires. This is to reduce the risk of mis-wiring causing a short. A magnetic connector might work for the signal wires, but I doubt that it could be used for the power wires.
      still requires wire but here is an example of magnetic quick change tools with what appears to be USB for quick disconnect.
      http://flux3dp.com
      Exploring the universe wherever the tech blows
        Whitewolf
        Phoenix Contact also makes some hybrid quick connect plugs and cables that run power and signal through a single cable
          @Whitewolf:
          Can you provide a link to the specific range of connectors?
            Whitewolf
            @dc42:
            https://www.phoenixcontact.com/online/portal/us?1dmy&urile=wcm:path:/usen/web/main/products/subcategory_pages/Hybrid_connectors_P-20-07-07/5a6e7875-620b-49aa-aad2-5cca1be81e12
              Whitewolf
              the connectors are sold as just connector or connector with cable factory soldered in various lengths. I used some of their products on my CNC machine, top quality stuff allowing compact design.
                Whitewolf
                They also work with different industries to make specialty terminal blocks and connectors. You might have some luck getting a hybrid connector made for 3d printers that uses the M8 profile if you do not need all the contacts that the M12 provides.
                  Thanks. Those are nice looking connectors, but at more than £25 per pair, too expensive for us to consider using.
                    Whitewolf
                    @dc42:
                    Always more than one way to skin a cat, I have not dug into any of these but it appears there are other options as well as some china knock off versions:
                    https://www.google.com/search?q=power+and+signal+cable+connectors+combination&client=safari&channel=iphone_bm&prmd=isvn&tbm=isch&tbo=u&source=univ&fir=aGCXvT9KytgLTM%253A%252C1RueKIH17FMnlM%252C_%253BMH4Q2os5un0Q4M%253A%252CX8DYikKozboJWM%252C_%253BP9bNreQSbdx6tM%253A%252CdEVZpbVkEvyLeM%252C_%253B7yhsBAv8gSkI-M%253A%252CYo0c6J3XmyN5kM%252C_%253BHo6HMWEtxXM84M%253A%252CYo0c6J3XmyN5kM%252C_%253BwSBv8FYC_hwHzM%253A%252C0822bA9po_LIOM%252C_%253BMmTncg7KEZrLRM%253A%252CJzgwlsC_AsbU1M%252C_%253BgmPBu-xsPnyQyM%253A%252CUUjgObmXNio_zM%252C_%253BACN_sCfquLrhwM%253A%252CkjO024cyXMP8GM%252C_%253Bfb97a8ynNtP9oM%253A%252CII9yHGby1R7gfM%252C_&usg=__zzkeWDuh-VOYuDOxIKq4bggKAKw%3D&sa=X&ved=0ahUKEwipyM7akpjUAhWhrFQKHQ5ADr4Q7AkIUw&biw=414&bih=628#imgrc=aGCXvT9KytgLTM:
                      Whitewolf
                      @dc42:
                      sorry bad link:
                      https://www.google.com/search?q=power+and+signal+cable+connectors+combination&client=safari&channel=iphone_bm&prmd=isvn&tbm=isch&tbo=u&source=univ&fir=aGCXvT9KytgLTM%253A%252C1RueKIH17FMnlM%252C_%253BMH4Q2os5un0Q4M%253A%252CX8DYikKozboJWM%252C_%253BP9bNreQSbdx6tM%253A%252CdEVZpbVkEvyLeM%252C_%253B7yhsBAv8gSkI-M%253A%252CYo0c6J3XmyN5kM%252C_%253BHo6HMWEtxXM84M%253A%252CYo0c6J3XmyN5kM%252C_%253BwSBv8FYC_hwHzM%253A%252C0822bA9po_LIOM%252C_%253BMmTncg7KEZrLRM%253A%252CJzgwlsC_AsbU1M%252C_%253BgmPBu-xsPnyQyM%253A%252CUUjgObmXNio_zM%252C_%253BACN_sCfquLrhwM%253A%252CkjO024cyXMP8GM%252C_%253Bfb97a8ynNtP9oM%253A%252CII9yHGby1R7gfM%252C_&usg=_zzkeWDuh-VOYuDOxIKq4bggKAKw%3D&sa=X&ved=0ahUKEwipyM7akpjUAhWhrFQKHQ5ADr4Q7AkIUw&biw=414&bih=628#imgrc=
                        Whitewolf
                        Not sure on pricing but lumbergautomation (Belden) makes a similar plug as well
                        • Dougal1957undefined
                          Dougal1957
                          they are also very bulky for installing on a effector and I suspect have considerable more mass than a pair of Molex headers which are probably just as quick to disconnect!
                          • A Former User?
                            A Former User
                            Cant you just use a suitable IDC connector for both signal and power
                            • elmoretundefined
                              elmoret
                              IDC isn't suitable for hotends, as they can draw 3.3 amps, even 5 amps in the case of some 60 watt cartridges.
                              • A Former User?
                                A Former User
                                @elmoret:
                                I was thinking along the lines of doubling up spreading the load across the connectors, 24v on a 60 watt heater cartridge comes out at 2.5 amps so if you use for example
                                16 way flat ribbon cable 28 AWG (7x36) Stranded 300V that should work.
                                Just in the same way some are powering nema 17's with CAT5/6
                                But hey I'm a Mech Eng not Electrical….
                                  Yes it's possible to use ribbon cable to carry power if you use enough conductors. My Ormerod 1 uses ribbon cable to power the 10A bed heater. I think it's a 40 way cable using 19 ways in each direction to carry the heater current and 2 for the thermistor. To connect a hot end this way, then in order to allow for using a 12V 50W heater plus fans etc. you would need about 28 conductors, making it quite a wide ribbon cable and difficult to wrap around a Bowden tube on a delta printer. A!so, you would want to have the Duet designed with a matching ribbon cable connector on it.
                                  For future intelligent hot end designs and Duets, I'm looking at using one RJ11 connector to carry the signals and a 2-pin power connector of some sort to carry 12V or 24V power. But for now the smart effector is designed to work with the current generation of Duet electronics (and perhaps other electronics too) so that is a not a possibility. On my own delta I plan to change the wiring to use two 8-core cables: one for the signals, and the other for the heater (using 2 pairs of conductors in parallel) and fans.
                                  • A Former User?
                                    A Former User
                                    @dc42:
                                    If you are going to dual 8 core (16 total) you could use the 4 twisted pair RJ45 plugs mated to PCB mounted 8 way RJ45 sockets and silicone 8 core wire should be flexible enough.
                                    • elmoretundefined
                                      elmoret
                                      @CaLviNx:
                                      Doubling up pins is bad practice. There's no way to guarantee the load is shared evenly - if the resistance of one is a bit different, the load seeks the lower resistance path.
                                      Ask Rigidbot how it worked out to spread a load across multiple pins. Here's an example:
                                      https://plus.google.com/101640661041406923828/posts/SL7EXPS1Rro
                                      Molex MicroFit connectors are rated for 5 amps and would be a more suitable choice.
                                      Nema17 over Cat5/6 is reasonable, as they make RJ45 connectors rated at 1.5 amps which is typical for a stepper motor. The biggest issue using network cable on a stepper motor is the repeated flexing.
                                      • kraegarundefined
                                        kraegar
                                        You can get stranded core RJ45 that's still rated for 1.5 amps.
                                        Co-Creator of the RailcoreII CoreXY printer
                                        https://www.thingiverse.com/thing:2407174
                                        • elmoretundefined
                                          elmoret
                                          Yes, but not everyone knows that. Better stated: The biggest issue with network cable on stepper motors is folks using solid core cable which can't handle the flexing.
                                          • A Former User?
                                            A Former User
                                            @elmoret:
                                            Bad practice… hahahaha
                                            Try being in the field and the company man is screaming to get the job done !!! If you think Deepwater Horizon was far fetched on that front think again... anyway
                                            "if" I was doubling up on pins I would be doing it for myself and not worry about a pissing contest of who did what where or when and live with the consequences of that choice.
                                            So to get back on topic I see a need (for me anyway) for the following to go the effector.
                                            X2 wires for the Heater cartridge. (of a suitable gauge to handle the required load)
                                            X2 wires for the Hot end temp signal
                                            X1 "live" to feed the hot end fan, cooling fan and any lighting (again of a suitable gauge to handle the required load)
                                            X3 "signal earths" for controlling the fans & lighting
                                            And any additional wires to cover the contact sensor requirements
