    Uneven layers
    58
    2005
    • Haggan90
      Haggan90 last edited by
      Hi!
      I'm trying to get rid of a really anoying problem..
      I get uneaven layers and I don't know what to do about it.
      The lines goes all around the part, so I know it can't be a miss alignment or bent leadscrew.
      Please look at the pictures, one is with 0.210 layer height and the other one is with 0.405 layer height.
      The pitch of the leadscrews is 3mm, so step per mm is 1066.67, could this be the problem?
      Oh and I'm using a 0.8mm nozzle on a volcano hot end with an BMG extruder.
      • Veti
        Veti last edited by
        since the lines are not consistent between both i would check positional accuracy.
        have the motors energised and grab the hotend with your fingers and try and move it. you should have none to very little movement.
        then check your extruder steps per mm are correct.
        Haggan90 1 Reply Last reply Reply Quote 0
        • Haggan90
          Haggan90 @Veti last edited by
          @veti hi,
          The lines are very consistent all around the print. It might not be 100% aligned on these two because one is 0.21mm layer height and the other one is 0.405mm.
            Is the bed heater in bang-bang mode?
            • Haggan90
              Haggan90 @Phaedrux last edited by
              @phaedrux Hi,
              So far I do not have a bed heater 😃
              First I thought it was a bent lead screw so I made a major upgrade to reinforce the whole bed assembly, but the problem remains =(
              Now I understand that it can't be the lead screws as the errors goes all around the part and not only on one side. If it were a bent lead screw I imagine that one side should be inwards and the the oposite side should be outwards.
              • deckingman
                deckingman @Haggan90 last edited by
                @haggan90 A few random thoughts. That's a very small part to be printing with a large nozzle. As I said in your other thread, you need a lot of part cooling with large nozzles. The time to print that outer perimeter will vary depending on which bits of the "X" and "Y" it had to effectively miss. So the layer time will vary. Which means each layer will have more or less time to cool than subsequent layers. To test that theory, try printing the same part without the "X" and "Y" impressions. Better still, print a much larger cube to see if you still get the same effect.
                  Is your bed heater running in PID or in bang-bang mode? A bed heater running in bang-bang mode can cause layer banding.
                  The banding on the right hand one has a very obvious course pitch. Is it 3mm?
                  deckingman Haggan90 2 Replies Last reply Reply Quote 0
                  • deckingman
                    deckingman @dc42 last edited by
                    @dc42 David. The OP said above that he doesn't have a bed heater.
                    • Haggan90
                      Haggan90 @dc42 last edited by
                      @dc42 No bed heather at the moment.
                      They have the same course pitch, and it's about 3mm apart on both.
                      The indents and outdents ar the same around the hole part.
                      I think it's like in the attached picture, and it occurs at the same height.
                      • Haggan90
                        Haggan90 @deckingman last edited by
                        @deckingman Hi,
                        That's why I tried to print both with 0.405mm and 0.21mm, both at very low speed.
                        I tried a big vase as well with the same results.
                        • Haggan90
                          Does anyone have any other ideas? 😃
                          I will try what @deckingman suggested and print a new larger cube without the X and Y imprints to see if the problem remains.
                          Could this has to do with the 1066.67 steps/mm on the Z steppers?
                          Would it be better if I geared them down 1:3 to get an even 3200 steps/mm?
                          Or maybe remove the lead screws and add belts instead?
                          • Veti
                            Veti last edited by
                            what kind of lead screws are they?
                            • Haggan90
                              @veti Hi Veti,
                              I bought them at Dold Mechatronik.
                              12x3mm
                              https://www.dold-mechatronik.de/navi.php?a=45805&lang=eng
                              They should be of high quality.
                              • Veti
                                Veti last edited by
                                i looked at the dold ones, but most of them were very uncommon.
                                i went with a SFU1204-DM like https://www.dold-mechatronik.de/navi.php?a=58147&lang=eng in the end. same diameter but 4mm lead.
                                • Haggan90
                                  @veti Yeah I know, but if I would to go with the ball circulating screws it would cost me >300€ =/
                                  • Veti
                                    Veti last edited by
                                    yeah dold is quite expensive.
                                    have a look at robotdigg
                                    https://www.robotdigg.com/product/614/1204-Ball-Screw-with-standard-Machined-Ends
                                    • Haggan90
                                      @veti I need 3 pcs and they need to be 840mm long.
                                      This has to be a last resort as I first want to figure out if I can solve it with the installation I got for now.
                                      There shouldn't be any problems with the ball screws I have, they are straight.
                                      • Haggan90
                                        Haggan90 @Haggan90 last edited by
                                        @deckingman here's a new test with a 50x50 cube and 0.6mm layer height. Same results.
                                        • antlestxp
                                          antlestxp last edited by
                                          how are your bearings on your z axis. do they move freely when you take off the lead screw? I had one of 4 of my bearings that was not as smooth at the others and it caused a similar issue.
                                          • Haggan90
                                            And here's the same print with 0.3mm layer height.
                                            • Haggan90
                                              Haggan90 @antlestxp last edited by
                                              @antlestxp Hi,
                                              Yes they move very freely.
                                              In my opinion it can't be any misalignment issue, as the indents/outdents goes all around the print (it's very clear on the 0.3mm picture)
                                              antlestxp 1 Reply Last reply Reply Quote 0
                                              • antlestxp
                                                antlestxp @Haggan90 last edited by
                                                @haggan90 in my case the bearing would reduce bed movement every few mm causing the layers to squish until the bearing pushed through its "tight" spot
                                                • T3P3Tony
                                                  T3P3Tony administrators @Haggan90 last edited by
                                                  @haggan90 said in Uneven layers:
                                                  measure the number of layers in the repeating pattern and then try a different layer height to see what impact it has. Those larger cubes without the X etc indentations make it easier to tie down the problem. It could be because you have non metric lead screws and the later heights don't add up to round numbers but if so this is pretty extreme banding for that.
                                                  www.duet3d.com
                                                  • deckingman
                                                    deckingman @T3P3Tony last edited by
                                                    @t3p3tony Tony,
                                                    We went through his lead screws and steps per mm etc in his other thread. His screws have a lead of 3mm which is unusual but means that one full step is 0.015mm. So providing he uses layer heights that are multiples of 0.015 then he should be using full steps and not relying on micro-stepping for positional accuracy. So 0.3mm layer height @1066.67 steps per mm @16X would be 320 micro steps or 20 full steps and 0.6mm layer height would equate to 40 full steps.
                                                    Even if the firmware rounds 1066.67 up to 1067 steps per mm then 0.3mm becomes 320.1 but you can't have 0.1 of a micro step so it would still send 320 (micro) steps. If the firmware keeps track of the fractional micro steps and adds one on when it gets to a full micro-step, then that would repeat at 3 mm but 1 micro-step is 1/10667 mm so that wouldn't be noticeable.
                                                    @Haggan90 Are you sure the lead of the screws is indeed 3mm and not say 1/8 inch? I only ask because 1/8 inch is 3.175 mm which might explain your banding if you set the steps per mm to 3mm. Clutching at straws here..........
                                                    • T3P3Tony
                                                      @deckingman thanks, missed the other thread.
                                                      @Haggan90 worth trying the different layer height slices anyway, now you have the cubes printing well and seeing if the repeatability of the issue is the same or different.
                                                      www.duet3d.com
