    Y Axis Zero at wrong end
    • MiracuruZRHundefined
      MiracuruZRH
      Dear all
      I have troubles to setup my Duet3D WiFi correctly.
      I'm on Firmware 2.02(RTOS) (2018-12-24b1)
      The problem is, that the Y Axis is moving in the wrong direction.
      When looking towards the printer, then Y0 is away from me. Therefore a G1 Y200 shifts the bed away from me.
      Y Endstop is at the Y+ side
      Y Motor is at the Y+ side
      Also all printed parts are mirrored in the Y direction.
      I've played already around with reversing the motor wiring and with the M586 and with the homeall.g file as well but none of them (or combination worked).
      X-Axis and Z-Axis are working normal.
      Have spend already many hours to figure out what's wrong but without look. Therefore reaching out to you for help.
      I've made a drawing for better clarification and also attached my configuration files and homing files.
      1_1558741873260_config.g
      0_1558741873260_homeall.g
      • nhofundefined
        nhof
        In the picture you posted, if the bed is moving in toward you, then isn't the nozzle moving in +Y direction relative to the bed/part, correct? Assuming since the bed moves then the nozzle is not moving in Y direction. A G1 Y200 should move the bed towards you on most standard bed-moving printers (prusa i3 style, etc).
        If this is the case then you need to change your motor direction (M569), endstop direction, and homing macro files.
        But I could be looking at the picture wrong.
          MiracuruZRH
          Dear @nhof
          Many thanks for your quick reply. I'm sorry to post my answer not sooner due to lot of work and also illnes unfortunately.
          I owe you something. You saved me hours of try and error. You were exactly right.
          May i ask you, What was unclear about the picture?
          Thats correct
          That solved my Problem. Thank you so much!
          A general question:
          In the duet wiki M574 --> Set endstop configuration
          The parameter S is described as: "Snnn Endstop type: 0 = active low endstop input, 1 = active high endstop input, 2 = Z probe, 3 = motor load detection".
          Therefore I'm confused. What exactly is the S parameter?
          Is it the the position at which side the endstop is positioned. At the low or at the high side of the Axis?
          Or is it rather a direction?
          I've uploaded also a picture of the current setup with the endstop marked with purple arrows and the corresponding parameter below.
          This combination worked.!
          My config.g file looks as follows now (working version):
          M569 P0 S0                                 ; X Achse 	 / S0 = Rückwärts S1 = Vorwärts
          M569 P1 S0                                 ; Y Achse 	 / S0 = Rückwärts S1 = Vorwärts
          M569 P2 S1                                 ; Z Achse 	 / S0 = Rückwärts S1 = Vorwärts
          M569 P3 S1                                 ; Extruder E0 / S0 = Rückwärts S1 = Vorwärts
          M574 X1 Y1 S1   			   ; End Stop // 0 = Kein, 1 = Low-End, 2 = High-End
          M574 Z1 S2      			   ; BL-Touch
            Phaedrux Moderator @MiracuruZRH
            @miracuruzrh said in Y Axis Zero at wrong end:
            The S parameter defines the switch type, as in Normally Open, Normally Closed, etc.
            The position of the endstop is defined by the number after the Axis letter. So X1 means the X endstop is at the low end of travel. Y2 means the Y axis endstop is at the high end of travel.
