    Duet Webserver documentation
    Duet Web Control
    449
    • SIam
      SIam last edited by
      maybee it can be that i'm blind! is there somewhere a Documentation for the build in Webserver with all rr_ commands ?
      regards
      Andy
      Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
      Duet WiFi 1.02 or later + DueX5
      RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
      Duet WiFi Server: 1.26
      Duet Web Control 3.4.0beta4 (2021-09-27)
      • resam
        resam last edited by
        https://github.com/chrishamm/DuetWebControl#list-of-http-requests
        (and related: https://github.com/chrishamm/DuetWebControl/issues/61)
        Kriechi created this issue in chrishamm/DuetWebControl
        closed Move API calls to Duet Wiki #61
        • SIam
          SIam last edited by
          this links i know! but there are not the complete documentation.
          • resam
            There is also the source code - with a nice documentation block at the top:
            https://github.com/dc42/RepRapFirmware/blob/36488de6fc6635f470b311c91fe282efe7a3e559/src/Duet/Webserver.cpp#L28-L83
            (but AFAIK it is also not complete)
            • T3P3Tony
              T3P3Tony administrators @SIam last edited by
              @siam what specifically are you missing?
              Duet Hardware Designer
              www.duet3d.com
              • SIam
                SIam last edited by
                ok in the c Code i have not looked i think it will help me a bit, what i havent found for now is how i get the information when z.b M300: Play beep sound or when M291 is executed with rr_reply i will nothing receive when i execute this two comands
                  In file RepRap.cpp you will find this in the code that generates the reply to rr_status:
                  		if (sendBeep || sendMessage || mbox.active)
                  			response->cat(",\"output\":{");
                  			// Report beep values
                  			if (sendBeep)
                  				response->catf("\"beepDuration\":%u,\"beepFrequency\":%u", beepDuration, beepFrequency);
                  				if (sendMessage || mbox.active)
                  					response->cat(',');
                  				beepFrequency = beepDuration = 0;
                  So you need to look for fields output/beepFrequency and output/beepDuration in the JSON status response.
                  • SIam
                    SIam last edited by
                    ok Thank you i will try it
