    Wiring a Da Vinci AIO to Duet Maestro?
    • Scally123undefined
      Scally123
      Hello all,
      I am currently in the process of upgrading my XYZ Da Vinci AIO to use a Duet Maestro. I have been following multiple different forum posts of other people upgrading their Da vinci 1/ Pro’s to either RAMPS or Duet as well as using the Duet wiki and Maestro board diagram.
      So far I have wired up the End Stops, Motors, Heated Bed, Bed Thermistor and Power in. I am currently trying to wire up the 7 pin connector that includes the Extruder Fan (yellow wire being +ve, green being –ve) the Extruder Thermistor (orange and black) leaving the two red and one blue. I believe these go to a switch on a small PCB where the filament feeds through before going into the heater. I think this is a switch that notifies that the filament is about to run out.
      On one of the posts I think this was labelled as a Rotary Encoder, however they were upgrading a Davinci Pro rather than an AIO. Would there be any need/provision to wire this switch into the Maestro?
      As for the Extruder Thermistor which connection should this be to? I am thinking it is the connection labelled as C Temp VSSA Thermistor 2. Is this correct as there are other connections labelled as thermistor connections?
      Also am I right in thinking that the extruder fan must be wired to the ALWAYS ON FAN Connection?
      I have been taking photographs as I go along and once I have successfully completed this I will upload it for others to follow.
      Any help is greatly appreciated.
      • T3P3Tonyundefined
        T3P3Tony administrators @Scally123
        @scally123 the rotary encoder could be used by the Davinci to sense filament movement (and possibly direction) as well as filament presence. There are a few people who I believe have made a pulse generator work with the Duet but not sure which one of if its the same as on the Davinci .
        The extruder thermistor would normally go to E0 on the Maestro :
        https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_Wiring_Diagram
        The extruder fan can be wired to an always on fan or to a PWM fan. the advantage of a PWM fan is the fan can be truned on thermostatically once the extruder temperature goes above a set temperature, see:
        https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M106_Fan_On
        specifically the settings for thermostatic control.
        www.duet3d.com
          Scally123
          Thanks for your reply Tony and confirming the fan and thermistor positions.
          I'm not sure whether it is just a switch that senses the if the filament has run out or if it is a rotary encoder.
          I'm working on it this weekend and hopefully I will get it up and running soon.
