IR Z Probe Settings
Hello again.
I had to switch to a microswitch Z stop for a while, but now i am putting the IR probe back to work. I have it mounted, and wired. It triggers just fine, and the Duet can read it. However, it triggers at 1.25mm above the bed like it should and I cant seem to set the Z offset so that it moves on down to zero. It stubbornly sticks to the Z height being exactly where it triggers the IR probe.
This seems like its a leftover setting from the Z probe time, But I am not able to tell where. I will attach my config.g and homeall.g files here, so you can point out what i missed.Config.G:
; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 22:23:49 GMT-0600 (Central Standard Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"AMV8" ; Set machine name
M552 S1 ; Enable network
M587 S"Awesome Sauce!" P"1q2w3e4r" I10.0.42.195 J10.0.42.1 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P4 S1 ; Drive 4 goes forwards
M350 X32 Y32 Z32 E32:32 I0 ; Configure microstepping without interpolation
M92 X160.00 Y160.00 Z845.00 E768.00:768.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E250.00:250.00 ; Set accelerations (mm/s^2)
M906 X1200.00 Y1200.00 Z1200.00 E900.00:900.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout
M564 H0 ; Allow movement without homing; Axis Limits
M208 X250 Y280 Z270 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops
M591 D0 P2 C3 S1 ; Set E0 endstop to filament runout microswitch on E0
M591 D1 P2 C4 S1 ; Set E1 endstop to filament runout microswitch on E1; Z-Probe
M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
G31 P500 X10 Y0 Z1.25 ; Set Z probe trigger value, offset and trigger height
M557 X30:200 Y30:240 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 ; Define tool 0
M563 P1 D1 H1 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
T0 ; Select first tool
Homeall.G:
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 Z10 F6000 S2 ; lift Z relative to current position
G1 S1 X-225 Y-285 F3600 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 X5 Y5 F6000 ; go back a few mm
G1 S1 X-225 Y-285 F1000 ; move slowly to X and Y axis endstops once more (second pass)G90 ; back to absolute mode
G1 X140 Y140 F36000 ; put the head wherever you want it to be when you home Z (omit this line if it doesn't matter)
G91 ; relative mode
G1 S1 Z-300 F700 ; move Z down until the switch triggers
G92 Z0 ; tell the firmware that we are at Z=0
G1 Z5 F500 ;lift Z a bit; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
@jkaechler said in IR Z Probe Settings:
G92 Z0 ; tell the firmware that we are at Z=0If you're wanting to use a probe to home, you will need to change this section to a G30 probe command.
As @Phaedrux says. See https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z_using_a_Z_probe.
That works! thanks.
Now my next challenge. When I try to run bed mesh compensation, it moves to the first probe point, and then on down to the bed. But the Z keeps going down, the probe lights up but does not trigger. After a couple seconds DWC will report 'Z axis did not trigger' and abort the auto bed compensation run.What do i have wrong on this one?
P.S. Phaedrux and DC42, thank you both for many answers and tips over the past year or so.
Happy to help.
Are you saying that the probe works when homing but not when doing G29?
Double check these guides
https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
