    RRF Configurator & PT100 on Maestro
    Firmware installation
    • JRDMundefined
      JRDM
      My uSD card died so I thought I'd try the RRF configurator to speed up setup.
      Heater 1 has a PT100 on it and I set up what I thought was the correct setup. RRFC spit out this line:
      M305 P1 X200 R2200
      It should have been:
      M305 P1 X200
      RRF seemed to get confused with the 'R2200' parameter. Once I removed 'R2200', the sensor worked fine.
      For the moment everything else seems fine.
      dc42undefined 1 Reply Last reply Reply Quote 1
      • PaulHewundefined
        PaulHew
        The 'R2200' parameter is required for a Maestro.
        If it was another board like the Duet2 i think is R4700.
        This is my Hotend heater line for a E3D V6
        M305 P1 T100000 B4725 C7.060000e-8 R2200
        And my Bed is
        M305 P0 T98801 B4185 R2200
        Looks like you are missing some parameters, possibly
        RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
        Voron 2.4 disassembled..... Waiting for the RailCore Mini....
          dc42 administrators @JRDM
          @jrdm said in RRF Configurator & PT100 on Maestro:
          M305 P1 X200 R2200
          M305 P1 X200
          RRFC seemed to get confused with the 'R2200' parameter. Once I removed 'R2200', the sensor worked fine.
          Thanks for pointing this out, we'll get it fixed.
            dc42 administrators @PaulHew
            @paulhew said in RRF Configurator & PT100 on Maestro:
            Actually the R parameter is almost never needed. The cases when it is needed are:
            • When using a Duet 085 or a later Duet 06 with a thermistor, because the default for these boards is 1000 but later boards use a 4700 ohm series resistor;
            • When using a PT100 with a third-party MAX31865 interface board, and the reference resistor on that board is not 400 ohms.
            • PaulHewundefined
              PaulHew
              @dc42 Learnt something again today!
