    KiCad source for PCB v2
    • NexxCatundefined
      NexxCat
      The github repo for the SmartEffector only contains the source for the v1.3 PCB, is v2 available anywhere?
      I'd like to use the source files to create a detailed model of the effector.
      Thanks!
      • T3P3Tonyundefined
        T3P3Tony administrators @NexxCat
        @nexxcat I have updated the repository, the soruce is there now:
        https://github.com/T3P3/SmartEffector/tree/master/SmartEffector/SmartEffector_v2.0
        Along with a step file that should help 😄
        www.duet3d.com
        • NexxCatundefined
          NexxCat
          You sir, are an absolute legend!
          That's perfect! Thank you very much 😃
          • clearlynotstefundefined
            clearlynotstef
            So funny, I was thinking today that I'd make a detailed model of the full effector, including the height of each component coming off of the bottom, so I could work out accessories and be sure the clearance actually works. Do you plan on sharing your model when you're done? I'd hate to duplicate efforts!
              clearlynotstef
              I'm working on a model of the smart effector which will include all of the SMD components and correct clearances, so the community (and me) can continue making awesome add-ons and such. Just started it recently and I work a whole lot so it might take me a while to actually finish it, but I'll share the f3d file which is properly broken into components and bodies, step, stl, and anything else that would be helpful.
              Still very much a work in progress:
