Zero upload capability
  • Ive had a duet 2 1.04 build running for the past week and have managed to use this forum to work out many of the issues i see other people having. Couple of issues though that persist through all the troubleshooting threads ive read that are related to uploading files. My connection is plenty fast sitting less than 2ft from a 2.4ghz source dedicated to the printer. Aside from the uploading sorcery the network is configured as it should be and connects as it should. Yes, ive made sure the microsd cards are sorted. The printer has a half dozen brand new fast 8, 16, 32gb cards available to use, all formatted fat32 64kb with read/writes at 90-170MBs, all of them function as they should as long as i dont expect an upload..... or try to edit any of the print gcode files, sys files edit no problem. Anytime i have attempted to edit a print gcode file in dwc it will corrupt that files data after i save. It would also be great to know for sure where i can pull the most recent .bin's of iap4e, duetwifiserver, duet2combined or better yet a link to all of the necessary files packaged if it exists (at least until i can upload zip packages). Config-g/M122 attached.
    Thx for the help.
    ![alt text](0_1559936245354_Screenshot2.png image url)
    0_1559936346914_M122 Diagnostics.txt
    ; generated by RepRapFirmware Configuration Tool on Sat May 25 2019 09:39:52 GMT-0400 (Eastern Daylight Time)
    M111 S0 ; Debugging off
    G21 ; Work in millimetres
    M208 X190 Y175 Z155 S0 ; Set axis maxima
    M550 Dup6Printer ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M92 X160 Y160 Z1600 E415 ; Set steps per mm
    M566 X900 Y900 Z50 E5000 ; Set maximum instantaneous speed changes (mm/min)
    ; M572 D0 S0.015 ; Set pressure advance (req trim retraction min of 50%)
    M201 X8000 Y8000 Z400 E8000 ; Set accelerations (mm/s^2)
    M203 X10000 Y10000 Z400 E10000 ; Set maximum speeds (mm/min)
    M204 P1000 T3000 ; Set maximum printing and travel accelerations
    M906 X1850 Y1850 Z1400 E1475 I20 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S10 ; Set idle timeout
    M574 X1 Y1 S0 ; Set active low endstops
    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5
    M558 P9 H5 F450 T4000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds. X,Y=NO Z=YES
    M557 X45:155 Y5:150 S36 ; Define mesh grid
    G31 P25 X40.0 Y-21.5 Z2.165 ; Set Z probe trigger value, offset and trigger height
    M671 X40:92:153 Y195:0:195 P0.5 ; adjusting screws at rear left (195,40),front middle(100,-10)and
    rear right(215,190),thread pitch 0.5mm
    M305 P0 T100000 B3988 C0 R4700 X2 ; Set thermistor + ADC parameters for heater 0 and remap it to channel 2
    M143 H0 S120 ; Set temperature limit for heater 0 to 90C
    M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M307 H1 A343.8 C253.5 D45 C24.1 S0.85 ; Set PID Autotune values for heater 1. 80w @ 600deg C
    M106 P1 S1 I0 F500 H1 T75 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    M563 P1 D0 H0 ; Define tool 1
    G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    T0 ; Select first tool
  • You and me both.
    I am guessing that you have seriously mismatched versions of the main firmware, wifi firmware and DuetWebControl. See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware?revisionid=HEAD#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_2_WiFi.
    I recommend you use main firmware (Duet2CombinedFirmware.bin) 2.02, wifi firmware (DuetWiFiServer.bin) 1.23, and DuetWebControl 1.22.6.
  • @dc42 Awesome dc, thank you. Ill give that a go.
  • @dc42 I updated to the versions you listed and no change, still cannot complete an upload with any type of file. I then updated firmware to your newest release 2.03rc5 and still no ability to complete an upload. I say "complete" because when it comes to uploading an update in .zip format it seems to upload certain files but then it always stops at the same ones to report an error.
  • @dc42 Can i send files through the usb?
    My guess is that the WiFi module isn't getting a strong enough signal. When you send the M122 command, what WiFi signal strength does it report?
    Have you tried setting your router to a different WiFi channel?
    Sending files over USB is possible, but slower than sending them over WiFi when the signal strength is sufficient.
  • @dc42 Tried to edit a gcode file stored on the mc and this was the result.
    Prior to any of the recent updating that you suggested it would just delete the file. It still deleted the file but it also appears to have corrupted dwc. I say that because unless i pull the card and reinstall dwc it wont work. Also, not sure if this is normal but the installation of dwc only unpacks the js folders zip which also happens to be one of the ones it errors when trying to update as a package through wifi.
    Looks like it failed to load the CSS file. If you refresh the browser tab, it may display OK. But I think your WiFi signal strength probably needs to be improved, see my previous response. There is a page about WiFi connectivity in the Troubleshooting section of the wiki.
  • @dc42
    It sits less than a meter away from its own dedicated Gbit router and i can use dwc its only uploads that tend to piss it off.
    1:57:37 AMM122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC5 running on Duet WiFi 1.02 or later
    Board ID: 08DJM-9178L-L4MSJ-6J9DL-3SD6Q-TV2GN
    Used output buffers: 3 of 24 (15 max)
    Static ram: 25680
    Dynamic ram: 94096 of which 0 recycled
    Exception stack ram used: 452
    Never used ram: 10844
    Tasks: NETWORK(ready,524) HEAT(blocked,1236) MAIN(running,3780) IDLE(ready,160)
    Owned mutexes:
    Last reset 02:39:03 ago, cause: power up
    Last software reset at 2019-06-09 23:14, reason: User, spinning module GCodes, available RAM 10908 bytes (slot 3)
    Error status: 0
    Free file entries: 10
    SD card longest block write time: 10.4ms, max retries 0
    MCU temperature: min 30.4, current 31.1, max 36.0
    Supply voltage: min 2.0, current 2.0, max 24.2, under voltage events: 1, over voltage events: 0, power good: no
    Driver 0: standstill, SG min/max 0/176
    Driver 1: standstill, SG min/max 0/213
    Driver 2: standstill, SG min/max 0/1023
    Date/time: 2019-06-10 01:57:36
    Slowest loop: 142.71ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 169, MinFreeDm: 165, MaxWait: 2923213ms
    === DDARing ===
    Scheduled moves: 29, completed moves: 29, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 200.40ms; fastest: 0.08ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      Failed messages: pending 0, notready 0, noresp 2
      WiFi firmware version 1.23
      WiFi MAC address ec:fa:bc:25:b3:67
      WiFi Vcc 3.34, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24360
      WiFi IP address 192.168.0.153
      WiFi signal strength -41dBm, reconnections 0, sleep mode modem
    -41dBm is a very good signal strength. I still think it's still worth trying a different WiFi channel. You could also try reducing the router power just in case the signal is too strong - I don't think I've seen a reported signal strength as high as that before.
    If that doesn't help, perhaps the WiFi module is faulty. If you want to swap the Duet, I will approve a replacement under warranty, assuming it's a genuine UK-manufactured Duet.
  • @dc42 Ok sure, ill have a look at that wiki but would it behave in this manner because it isnt getting a strong signal? deleting...corrupting and such? The wifi antenna is pointing directly at the router with no obstructions less than 3 feet away.
    This is a shot of the www directory after it corrupted dwc for attempting to edit gcode. noticed that js directory is empty.
    Uploading a file will delete any previous file with the same name. If the upload fails then you should never get a corrupted file because the partially-uploaded file will be deleted.
  • @dc42 Well its never successfully uploaded anything that ive wanted it too so i havent seen that. That installation of dwc in the www dir was manual pc to card and M997 S2 once back in the boards card slot. I really dont get the impression there is a hardware issue because everything works hardware wise. It connects to its network, prints, tunes, responds to code, communicates to any terminal ive tried. It just gets pissed when i ask it to upload.
  • @formfab
    If it responds to a terminal, for example YAT then that would demonstrate upload capability correct? lol Im a machinist not a network engineer so apologies if that is a silly question.
    @formfab said in Zero upload capability:
    As you have already tried several different SD cards, I suspect either a hardware issue with the WiFi module, or an incompatibility between the ESP12S WiFi module and your router.
