    Config file for FT5 R2
    • CarlBossonundefined
      CarlBosson
      Dose any one have a good config file for the FT5 R2 using the duet 3D?
      There is no box!
      • DanLundefined
        DanL
        Here's my FT5 R-2 config. I copied it below with the heading of my post asking for comments about it. Got a lot of good feedback. Look for the whole thread on June 4 to see more details.
        This config runs really well and is set up primarily for ABS temps. I make most process settings in Simplify 3D, and use S3D scripts to start and finish prints.
        Note too that I use an inductive height sensor, a filament runout sensor, have both Y steppers on separate drives, have changed pulley sizes so steps are non-FT, and have customized some of the files, so you may need more info than shown in the config.
        Review rookie config.g please
        DanL 4 Jun 2019, 15:10
        The Duet WiFi has made my FolgerTech FT5-2 printer run amazingly well. My general config.g settings seem to work really well over a wide speed range, for large and small parts and for ABS and PLA. (I use S3D and its' start/stop scripts for individual run settings)
        But I have a few questions about the config.g structure (syntax? whatever it's called) and how some of the Gcode is used. Some specific Q's are embedded in config line comments below.
        Could I please ask for comments on what might need to change, be added or deleted?
        I print 3-5x per week, wide range of parts, as a hobbyist. No need for efficiency or fancy config...just want a proper, basic config.g.
        Thank you.
        ; generated by RepRapFirmware Configuration Tool v2 on Sat Apr 13 2019 09:39:04 GMT-0700 (Pacific Daylight Time)
        ; Ver. 27APR2019 - New Duet Board
        ; Ver. 11MAY2019 - update movement settings
        M111 S0 ; Debug off
        G21 ; set units to mm
        M912 P0 S5 ; CPU temp calibration offset
        M555 P2 ; Set output to look like Marlin
        M550 P"FT5-2 Mod Duet" ; Set machine name
        M552 S1 ; Enable network
        ;M587 S"SHOP2" P"'X'X'X'Xnnnn" ; Config access point. Delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M575 P1 B57600 S1 ; Set auxiliary serial port baud rate and require checksum
        (for PanelDue)
        M584 X0 Y1:4 Z2 E3 ; sync left and right Y steppers on drivers 1 and 4.
        M569 P0 S1 ; X Drive 0 forward
        M569 P1 S0 ; Left Y Drive 1 backward
        M569 P4 S1 ; Right Y Drive 4 (E1) forward
        M569 P2 S0 ; Z Drive 2 backward. Bed moves down for Z+, up for Z-
        M569 P3 S1 ; E0 Drive 3 forward
        M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation
        M350 E16 I1 ; may change extruder to 32 later
        M92 X100.00 Y100.00 Z1000.00 E420.00 ; Set steps per mm E calibrated
        M566 X800.00 Y800.00 Z30.00 E1000.00 ; Set maximum instantaneous speed changes - JERK (mm/min)
        M203 X9000.00 Y9000.00 Z1000.00 E1000.00 ; Set maximum speeds (mm/min)
        M201 X800.00 Y800.00 Z500.00 E800.00 ; Set max accelerations (mm/s^2) (was 2k,2k,60,800 pre 11may19)
        M906 X900.00 Y800.00 Z1000.00 E800.00 I40 ; Set motor currents (mA) and motor idle factor in per cent
        M208 X300 Y300 Z350 S0 ; Set axis maxima
        ; End Stops
        M574 X2 Y2 S0 ; 2=endstops at x300 y300 high end. S0=active low, N/O switch
        M591 D0 P2 C3 S1 ; Filament sensor. D=E0, P=NC mswitch, C3=EO endstop, S1=enable, 0=disable
        M574 Z1 S0 ; Set Z probe as Z endstop
        M558 P5 H3 R0.2 F200 T6000 I1 ; P5 is switch, H 3mm, F speed, Trav speed, I1 invert activation, Recovery time
        M557 X28:280 Y24:276 S42 ; Define mesh grid 7x7, includes inductive sensor offset from nozzle X-19mm
        G31 P500 X-19 Y0 Z0.5 ; Set Z probe trigger value, offset and trigger height
        ; Heaters M307 params… Run M307 H# for params report
        ; Bed
        M305 P0 T100000 B3950 R4700 S"Bed" ; Set thermistor + ADC parameters for heater 0 Bed
        M307 H0 A150.5 C1276.9 D4.4 V24 B0 ; PID
        ; Extruder
        M305 P1 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 1
        M307 H1 A395.4 C174 D4.1 V24 B0 ; PID
        ; Chamber... No heater, but want to see chamber T
        M305 P2 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 2
        ; M141 H2 ; Assign chamber heater Disable heater assignment with neg number
        ; M143 H2 S80 ; Set temperature limit for heater 2 to 80C
        ; M307 H2 ; chamber heater operates in bang-bang mode
        ;M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
        ;M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M563 P0 D0 H1 ; Define tool 0 Uses E0 and Heater 1
        G10 P0 S0 R0 ; Set initial tool 0 active S and standby R temperatures
        M302 P0 S190 R190 ; set min extrude /retract T's
        M563 P1 S"Chamber" H2 ; creates tool w/no drive, but displays chamber T. No heater
        M501 ;load config.g on startup
        DanL
          CarlBosson
          Thank you
          There is no box!
