My New Effector Plate
Wow, that is just beautiful! How well does your Piezo Z-Probe work?
The piezo's working great - I need to contribute some data to the probe repeatability test, but it's been awesome. (I posted my mount for it in the piezo probe thread)
Hello, just wow !
I currently have a 713maker hotted mount, will it be possible to share your step files ? I've got a laser cutter at my job, I'd like to give it a shot
I can share the step files I provided 713maker, but they were awesome enough to trim them down much further than I had - this was based off of a part I printed, so the original revision I sent them was fairly bulky. They kept the spacing for everything, but slimmed it way down.
What is your rod spacing? I would like to incorporate this into my future build. I need the carriage for a mr12 linear rail H block however. I have the 713 ball cup setup now. Switching over to mag arms and mr12 for a big delta build.
If the Piezo Z-Probe works great you should get 713 to make something up. Just saying.
I went with a 50mm spacing. The plate has it built in, and then the adapters work with whatever carriage that has the same mounts as the seemecnc barbells (either the injection molded ones, or the tricklaser ones I'm using now). I have something totally new brewing for a carriage, though. Hope to be able to post it by this time next week!
As for the piezo, it works great with the 713maker mount, and a few printed parts. I've put them up here: https://www.thingiverse.com/thing:2268205
New to this forum.
Been looking for a aluminum effector for my DIY Delta build. I really like the 713maker E3D V6 mount and Effector, but the Effector is not compatible with Haydn Huntley's magnetic arms and balls. Yours looks like it will work great.
Is it possible to order one of those effector plates from you or 713maker?
