Power in watts motor PAP
  • Hi, I'm building a prototype test for a pellet extruder that can print directly, I need konw what is the real power or at least an estimated value of a stepper motor nema 23 of 112mm in length and 4.2A, if the source is 48, this is to know more or less which gearbox should use.
    I would also like to know your opinion on two types of gearboxes:
    This fits more to my taste, because I can put the screw extruder directly into the reducer, I'm thinking of using a 15: 1 ratio, but according to the manufacturer the maximum torque with that configuration is 3Nm, which does not make sense if the motor has 2.5NM
    and this other option with the 16: 1 reduction the specification table shows something more promising.
    I appreciate your attention and your cooperation.
