    Duet2 ethernet without drivers
    • 3DOesteundefined
      3DOeste
      Hi, I want to build my own injection molding robot and was looking the best hardware to do it, but I will use external drivers.
      Will a duet2 or a duet3 board without on board drivers, aim at controling industrial servos only be made in the future?
      I'm also considering machinekit with a beaglebone but since I become very familiar with RRF I would really preffer to use a Duet family product,
      • Vetiundefined
        Veti
        there is an lpc port of the rrf
        https://github.com/sdavi/RepRapFirmware
        it runs on the rearm platform that where you can put your own drivers.
        • T3P3Tonyundefined
          T3P3Tony administrators @3DOeste
          @3doeste unless you need more than 7 external drivers the easiest option is to use a Duet 2 Ethernet and take the 5 drivers from the expansion hears and the 2 from the Conn_LCD connector if you need them. You will be buying 5 internal drivers without using them but AFAIK the Duet is cheaper than a SAM4E dev board!
          www.duet3d.com
