    Solved [solved] Problem with M574
    m574
    • tech-raton
      tech-raton last edited by tech-raton
      I'm building a printer with 4 Z belts.
      I'm using a DuetWifi with DUEX5.
      I'm using the 2.03 release.
      I want 4 microswitch on the high end of the printer, to home.
      I am not able to set up the right endstop number.
      In my config.g file, there is:
      M584 X0 Y1 E3 Z6:7:8:9 U7 V8 W9
      Endstops
      M574 Z2 S0 C6 ; Set active high endstops
      M574 U2 S0 C7
      M574 V2 S0 C8
      M574 W2 S0 C9
      M915 X1 Y1 S3 R0 ; S3, Threshold
      M671 X302.5:-302.5:-302.5:302.5 Y-248:-248:248:248 S2 P40
      When I check on the Machine Properties, the endstop are not on the right stepper.
      I tried to change the number and nothing changes.
      The Z physical pin is still linked to the Z logical drive. It should be the C6 pin (M574 Z2 S0 C6)
      the same problem remain on the other drives.
      There's probably something that i'm missing, but I could use some help...
      Thank you.
      My complete config.g is here.
      M550 P"COREXY" ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M584 X0 Y1 E3 Z6:7:8:9 U7 V8 W9 ; Apply custom drive mapping
      M569 P0 S1 ; moteur A vers l'avant
      M569 P1 S1 ; moteur B vers l'avant
      M569 P3 S1 ; EXTRUDEUR
      M569 P4 S1 ; rien de branche
      M569 P5 S1 ; rien de branche
      M569 P6 S0 ; moteur4
      M569 P7 S1 ; moteur3
      M569 P8 S0 ; moteur2
      M569 P9 S1 ; moteur1
      M667 S1 ; Select CoreXY mode
      M350 X16 Y16 Z16:16:16:16 U16 V16 W16 E16 I1 ; Configure microstepping with interpolation
      M92 X160.00 Y160.00 Z160.00:160.00:160.00:160.00 U160.00 V160.00 W160.00 E2700.00 ; Set steps per mm
      M566 X900.00 Y900.00 Z900:900:900:900 U900 V900 W900 E120.00 ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z6000.00:6000.00:6000.00:6000.00 U6000.00 V6000.00 W6000.00 E1200.00 ; Set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z500.00:500.00:500.00:500.00 U500.00 V500.00 W500.00 E250.00 ; Set accelerations (mm/s^2)
      M906 X800.00 Y800.00 Z1400.00:1400.00:1400.00:1400.00 U1400.00 V1400.00 W1400.00 E500.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M671 X-50:-50:550:550 Y-40:440:-40:440
      M208 X-232.5 Y-178 Z0 S1 ; Set axis minima
      M208 X232.5 Y178 Z300 S0 ; Set axis maxima
      M574 U2 S0 C7
      M574 V2 S0 C8
      M574 W2 S0 C9
      ;M574 Z1 S2 ; Set endstops controlled by probe
      M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P500 X0 Y0 Z0.1 ; Set Z probe trigger value, offset and trigger height
      M557 X0:400 Y0:350 S20 ; Define mesh grid
      M305 P0 S"bed" T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
      M143 H0 S100 ; Set temperature limit for heater 0 to 120C
      M305 P1 s"buse" T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
      ; capteurs de température
      M305 P103 X2 S"radiateur" T100000 B4138 R4700
      M305 P104 X5 S"bed2" T100000 B4138 R4700
      M305 P105 X4 S"heatsink" T100000 B4138 R4700
      M305 P100 S"MCU"
      M305 P101 S"Duet"
      M305 P102 S"Duex"
      ; Fans 24V
      M106 P0 C"pompe" S0 I0 F12000 H-1 ; Berdair 24v a l'arret pour commencer
      ; Fans 12v
      M106 P3 C"pompe_a_eau" S0.8 I0 F500 H-1 ; pompe à eau au max (valider la réduction possible du PWM)
      M106 P4 C"ventil" S0.05 I0 F500 H-1 ; ventilateur derriere le SSR
      ; Leds 12v
      M106 P5 C"Rouge" S1 I0 F500 H-1 ; led rouge
      M106 P6 C"Vert" S1 I0 F500 H-1 ; led rouge
      M106 P7 C"Bleu" S1 I0 F500 H-1 ; led rouge
      M563 P0 D0 F0 H1 ; Define tool 0
      ; choses à ajouter
      ;firmware retract
      ; filament diameter
      ; pressure advance
      T0
      • deckingman
        deckingman @tech-raton last edited by
        @tech-raton It's because M574 has been withdrawn (yes, I was pretty miffed about it too). It was only introduced in a beta version but it had some impact on another command which upset some CNC users. So your choices are to go back to an earlier RRF 2 beta that did support M574 or try one of the RRF3 betas that (I think) support M574.
          dc42 administrators @deckingman last edited by
          @deckingman said in Problem with M574:
          To expand on Ian's answer, it's the M574 C parameter that was introduced in one of the RRF 2.03 beta versions and later withdrawn. It's available in a different form in RRF 3, see https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M574. RRF 3 also supports multiple axis motors + endstop switches without having to create additional axes.
          tech-raton 1 Reply Last reply Reply Quote 0
          • tech-raton
            tech-raton @dc42 last edited by
            I tried without the c parameter, and my z endstop is not the endstop number 6 even with m584 z6.
            Is that a normal behaviour?
              dc42 administrators @tech-raton last edited by dc42
              @tech-raton said in Problem with M574:
              Yes. In RRF2 endstop inputs are allocated to X Y Z E0 E1 E2 etc. in the order that axes are created. Use of M584 to remap axes to different drivers does not remap endstop inputs.
              • tech-raton
                Ok i understand.
                I'll switch to rrf3 so, to be able to have this multiple endstop working...
                Thank tou for your patience and this wonderful piece of hadware (and software)
                It's great to keep it opensource with a really strong support.
                Keep up the good work!
                • tech-raton
                  With rrf3, it worked nicely
                  Thank you very much.
