    Solved Configure M106 P2
    315
    • juanmena
      juanmena last edited by
      I need my sliced send M106 Sxx and run the fan P2 (Fan layer) and P1 is the fan and works with the temperature of the Hotend. The P1 works perfectly, but the P2 does not make it work M106 Sxx
      M106 P2 C"CAPA" ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 T45 H1 C"HOTEND" ;Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      Thank you
        By default the hotend fan should be connected to Fan0 Fan1, and the Part cooling fan should be connected to Fan1 Fan0. That keeps things consistent with the slicer.
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans
          dc42 administrators @Phaedrux last edited by
          @phaedrux said in Configure M106 P2:
          By default the hotend fan should be connected to Fan0, and the Part cooling fan should be connected to Fan1. That keeps things consistent with the slicer.
          I think you meant the other way round.
            Phaedrux Moderator @dc42 last edited by
            @dc42 Yes, of course.
            • juanmena
              Right, but the Fan 0 exit spoiled me and I have to look for an alternative
                Do you mean Fan0 port is not working?
                  You can use M563 F parameter to define your tool with any fan you like.
                  https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
                  • juanmena
                    RESOLVED:
                    M106 P1 T45 H1 C"HOTEND" ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                    M563 P0 D0 H1 F2 ; Define tool 0
                    Thank you
