    Thermocouple short question
    type k
    • dang472undefined
      dang472
      I don't understand the short error from my thermocouple.
      If I have a thermocouple and a heater connected to the duet but not in the heater block and I power on I don't have a short.
      The moment I put both in the heater block and then power on I get a short.
      If I connect the thermocouple after being powered on, I don't get a short.
      If I put a continuity tester between the thermocouple wiring and the heater wiring there is no continuity anywhere.
      What could be going on?
      Latest 2.0.3 firmware. Brand new e3d thermocouple. Haven't heated yet.
      • sibluesundefined
        siblues
        Have you tried checking continuity between the wiring and heater block?
        • A Former User?
          A Former User
          Seems strange if it were a issue where the voltage of the meter it to low to indicate a leakage but the board does. You don't happen to have a high voltage insulation tester or know someone with one?
          And just to confirm, you are measuring the continuity under the same circumstance the board is giving the error?
