    M571: Set output on extrude
    1
    440
    • Alexander Mundyundefined
      Alexander Mundy
      Does this change the state of the selected pin only while extruding or does it also trigger while retracting? If so, I assume it triggers when unretracting? If only when extruder going forward, what is worst case timing between motor and pin state changes?
