Change Z-heigt Anycubic Predator
  • Hi Guys,
    I hope I put this thread into the correct forum. If not, sorry.
    I want to change the Z-height. If I enter G1 Z0 the nozzle is 0.6 mm above the bed. I want to have it on 0 (= the nozzle scratches a piece of paper).
    What do I have to enter into the config or the config-override file? As far as I understood you need the currect information of M665 and M666, correct?
    I have a Anycubic Predator.
    Firmwarename: RepRapFirmware for Duet 2 WiFi/Ethernet
    Firmware Elektronik: Duet WiFi 1.02 or later
    Firmware Version: 2.0(RTOS) (2018-06-05b3)
    WiFi Server Version: 1.21
    Web Interface Version: 1.22.6
    Config.g file
    M665 R227 L440 B185 H455
    M666 X0 Y0 Z0
    Last code in config.g
    M501
    config-override.g
    M665 L440.000 R227.230 H453.007 B185.0 X0.199 Y-0.293 Z0.000
    M666 X-0.850 Y0.932 Z-0.083 A0.00 B0.00
    If you need further information, please let me know.
    Thank you
    Chaosfreak
  • Have you seen https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer yet? It's quite comprehensive and I had it printed out and lying next to my Delta almost like a check list.
  • fixed.
    I did the full calibration again.
    Thanks
  • This post is deleted!
