    notifications upon start/pause/finish of print
    Third-party software
    18
    65
    6.4k
    • Torinundefined
      Torin
      Hiya,
      Just wanted to share with you my solution for missing notifications/actions for Duet upon change of print status.
      I've builtin pushbullet/pushover/email support into it. You can also define some system commands/scripts to execute after status change.
      Please have a look and feel free to use it, grab the code do whatever you want.
      I've precompiled sources for Linux/OSX/Windows.
      https://gitlab.com/Toriniasty/reprap_notify
      Latest version: https://gitlab.com/Toriniasty/reprap_notify/-/releases
      Nxt-1undefined GeneRisiundefined 2 Replies Last reply Reply Quote 3
      • zaptaundefined
        zapta
        Very nice.
        • T3P3Tonyundefined
          T3P3Tony administrators
          Good work - like how it integrates with different push notification services.
          www.duet3d.com
          • Torinundefined
            Torin
            Cheers. I've tried it to make as simple as possible, so if there are any other services you guys would like to see and ideally if there's go module for it let me know it should be fairly easy to add.
            Also if you have any problems - shout πŸ™‚
            Or just feel free to push merge request πŸ™‚
            zaptaundefined 1 Reply Last reply Reply Quote 0
            • zaptaundefined
              zapta @Torin
              Next we need a machine learning module that looks at the print via a camera and sends a notification when things go wrong. https://www.tensorflow.org
              EDIT: similar to this one but detecting mess instead of forks https://play.google.com/store/apps/details?id=ninja.nanja.app.forkdetector
              Torinundefined 1 Reply Last reply Reply Quote 0
              • Torinundefined
                Torin @zapta
                @zapta https://www.thespaghettidetective.com/ <-that.
                • A Former User?
                  A Former User
                  ☝ that. especially like that you can self host it
                    jay_s_uk
                    I'd be interested in telegram support
                    • zaptaundefined
                      zapta @Torin
                      @torin said in notifications upon start/pause/finish of print:
                      Very nice! Now we need an open source one that doesn't require octoprint. πŸ˜‰
                      (I am trying to avoid those print servers and Duet makes it very easy)
                      • Torinundefined
                        Torin @jay_s_uk
                        @jay_s_uk If you will open releases page it should be there(v3) in about 10-15 minutes, it's building as we speak.
                        Brief instructions in the readme.
                        • tagliaundefined
                          taglia
                          Hi all. I've been using this for quite some time and it has always been very reliable. Unfortunately, the API response format has changed (I noticed this in RRF v3.2beta4). I have fixed the problem, but I don't have the time right now to make it generic and support both the old and new versions of the firmware.
                          @Torin I have submitted a merge request.
                          If anyone has this problem, you can get my fork.
                          • Torinundefined
                            Torin
                            Merged πŸ™‚ Cheers dude!
                            • scumdeadundefined
                              scumdead
                              Bonjour,
                              Je rencontre un problème avec reprap notify :
                              "Error parsing JSON: json: cannot unmarshal array into Go struct field .fanRPM of type int"
                              J'ai une duet 2 wifi en 1.04, et j'utilise RRF 3.2.1.
                              J'aimerais beaucoup pouvoir recevoir un email en fin d'impression...
                              Merci pour votre aide.
                              • Torinundefined
                                Torin @scumdead
                                @scumdead Can you give it a go with new release?
                                https://gitlab.com/Toriniasty/reprap_notify/-/releases/v5
                                Also could you please write in english, I only understood what you've said because of the error in the post. Hope it will be all good now.
                                Also added re-notify feature.
                                mct82undefined 1 Reply Last reply Reply Quote 0
                                • scumdeadundefined
                                  scumdead
                                  Thanks for the answer, I’m testing this day, and tell you if it works.
                                  Sorry for my poor english.
                                  • A Former User?
                                    A Former User
                                    @Torin
                                    This would be cool as a plugin 😎
                                    • scumdeadundefined
                                      scumdead
                                      It works perfectly, thank you very much.πŸ‘
                                      (Linux amd64 version)
                                      • Torinundefined
                                        Torin @A Former User
                                        @LB If you're talking about renotification then it is already there πŸ˜‰
                                        A Former User? 1 Reply Last reply Reply Quote 1
                                        • A Former User?
                                          A Former User @Torin
                                          @Torin
                                          YUHUU!
                                          😡 but where:
                                          Do I have to download something and import it or how would it work?
                                          • Torinundefined
                                            Torin
                                            @LB said in notifications upon start/pause/finish of print:
                                            Ah. Okey. To be fair, I haven't seen plugins functionality and I'm not sure how it is supposed to work. Maybe one day I will have a look and see if there's any possibility.... Anyhow, to make the notifier work just download one file from release page matching your system that's running, configure it via example yaml file and start it.
