notifications upon start/pause/finish of print
@nxt-1 I would unify
/machine/status
andrr_model
, then you can use basically the same data in your code. DSF 3.5-b1 will be able to emulaterr_
requests (except forrr_status
andrr_config
), too. -
I'm not sure I'm following what the issue is or if there is a better / neater way (than I use) .
In an attempt to assist, I posted an excerpt of code that I use in most of my (python) applications. DuetLapse3 etc.
https://forum.duet3d.com/topic/11088/notifications-upon-start-pause-finish-of-print/44
Is this sub-optimal? about to be outdated? just clumsy?
undefined stuartofmt referenced this topic
@stuartofmt That's alright since it already uses the object model.
@Torin Hello! I tried using this to send a text message to my phone via email. I have "email: 1234567890@vtext.com" and I keep getting messages from mail-daemon@comcast.net that delivery failed permanently and the recipients is "(empty line)". Is it possible that the email address starting with a number is not working as intended?
Thanks! -
This post is deleted!
