    Heater Faults of unknown origin
    392
    • samuelmennegaundefined
      samuelmennega
      I am running the Duet WiFi 2 on a cr-10s5 with the E3d Supervolcano hotend. I have the silicone sock installed and I have run the autotune function for this hotend. I run 12+ hour print files at work all the time, and a large portion of my prints pause themselves 1-2 hours from the end and throw a heater fault. By the time I arrive at work the next morning, the Duet has already abandoned the print, and the gcode log is so full of checksum errors I can't get to the original error. I have never once had a heater fault while I'm in the room. I need some help getting to the bottom of the issue.
      • Vetiundefined
        Veti
        see
        https://duet3d.dozuki.com/Wiki/Logging
          samuelmennega
          Ok, thanks for the tip, I enabled logging. I am curious if the faults are a result of the high filament flow rate going through the hotend. It is designed for ludicrous volumetric output and it delivers, however I tuned the PID's with it just sitting there, maybe the amount of cold filament running through affects the heating parameters?
          • Vetiundefined
            Veti
            but the checksum errors might be something else.
            what firmware version are you running?
            see
            https://forum.duet3d.com/topic/4245/checksum-errors
            dc says it might be a problem with the panel due connection.
            samuelmennegaundefined 1 Reply Last reply Reply Quote 0
              samuelmennega @Veti
              @veti I am running 2.0(RTOS) (2018-06-05b3).
              I do have a paneldue, I have researched this before and I never got conclusive results, so I just live with it.
              • Vetiundefined
                Veti
                just disconnect the paneldue for a few prints and see if you still get the checksum errors.
                • JamesMundefined
                  JamesM
                  If the super volcano uses a cartridge thermistor like the regular V6 hotend I would try gently wiggling the thermistor wires and see if you notice temperature changes. I had a couple of them go bad since I hadn't properly fastened the wires and the movement over time caused issues.
                  Needless to say I bought a couple of them and since fastening the wires from the heater cartridge and thermistor properly I haven't had an issue since with my normal V6 hotend.
                    dc42 administrators @samuelmennega
                    @samuelmennega said in Heater Faults of unknown origin:
                    Have you seen this thread https://forum.duet3d.com/topic/11104/paneldue-checksum-errors-when-heater-on-or-hand-near-pdue-cable/4 ?
